Have Certificate from Certbot but site is not HTTPS
My domain is: reve.works
I ran this command: sudo certbot certificates
Found the following certs:
Certificate Name: reve.works
Serial Number: 389e3223373134a74ddc7766267955b1dad
Key Type: ECDSA
Domains: reve.works www.reve.works
Expiry Date: 2023-09-04 22:13:47+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/reve.works/fullchain.pem
Private Key Path: /etc/letsencrypt/live/reve.works/privkey.pem
My web server is (include version): Apache2
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: OCI
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 2.6.0
Hi @reve Welcome to the forum.
Would you please share the command you used to obtain the certificates?
You answered most of the questions and we have enough to get on path for a resolution for you, but your installation command may give us the reason your certs are not actually in use yet.
Thanks
I'd like to see the output of:
sudo apachectl -t -D DUMP_VHOSTS
[and more, but we'll start there]
I think I did sudo certbot --apache -d reve.works -d www.reve.works. I did not do certonly, if that is what you are asking.
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443  reve.works (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80   is a NameVirtualHost
  default server 127.0.1.1 (/etc/apache2/sites-enabled/000-default-le-ssl.conf:40)
  port 80 namevhost 127.0.1.1 (/etc/apache2/sites-enabled/000-default-le-ssl.conf:40)
  port 80 namevhost 127.0.1.1 (/etc/apache2/sites-enabled/000-default.conf:1)
Let's have a look at this file:
Rudy's CLI request is spot on.
You might also try and post:
grep -ERi ServerName /etc/apache2
is an annoying warning but the grep command will show you where to add your server name... (most likely)
/etc/apache2/mods-available/status.conf:        # with the URL of http://servername/server-status
/etc/apache2/mods-available/info.conf:  #  http://servername/server-info (requires that mod_info.c be loaded).
/etc/apache2/mods-enabled/status.conf:  # with the URL of http://servername/server-status
/etc/apache2/sites-available/000-default-le-ssl.conf:   # The ServerName directive sets the request scheme, hostname and port that
/etc/apache2/sites-available/000-default-le-ssl.conf:   # redirection URLs. In the context of virtual hosts, the ServerName
/etc/apache2/sites-available/000-default-le-ssl.conf:   #ServerName www.example.com
/etc/apache2/sites-available/000-default-le-ssl.conf:ServerName reve.works
/etc/apache2/sites-available/000-default.conf:  # The ServerName directive sets the request scheme, hostname and port that
/etc/apache2/sites-available/000-default.conf:  # redirection URLs. In the context of virtual hosts, the ServerName
/etc/apache2/sites-available/000-default.conf:  #ServerName www.example.com
/etc/apache2/sites-enabled/000-default-le-ssl.conf:     # The ServerName directive sets the request scheme, hostname and port that
/etc/apache2/sites-enabled/000-default-le-ssl.conf:     # redirection URLs. In the context of virtual hosts, the ServerName
/etc/apache2/sites-enabled/000-default-le-ssl.conf:     #ServerName www.example.com
/etc/apache2/sites-enabled/000-default-le-ssl.conf:ServerName reve.works
/etc/apache2/sites-enabled/000-default.conf:    # The ServerName directive sets the request scheme, hostname and port that
/etc/apache2/sites-enabled/000-default.conf:    # redirection URLs. In the context of virtual hosts, the ServerName
/etc/apache2/sites-enabled/000-default.conf:    #ServerName www.example.com
These two files overlap:
And the one that has "le-ssl" is clearly NOT doing SSL.
With applied noise reduction:
With even more more applied noise reduction:
Can we see this file too:
Struggling with Filezilla, but I actually had a copy of that file from earlier:
<IfModule mod_ssl.c>
<VirtualHost *:443>
	# specifies what hostname must appear in the request's Host: header to
	DocumentRoot /var/www/html
	# error, crit, alert, emerg.
	# modules, e.g.
	#LogLevel info ssl:warn
ServerAlias www.reve.works
SSLCertificateFile /etc/letsencrypt/live/www.reve.works/fullchain.pem
SSLCertificateKeyFile /etc/letsencrypt/live/www.reve.works/privkey.pem
</VirtualHost>
</IfModule>
Is this block included in your config file?
Are you managing this server from a windows box?
Yes
Yes. My PC runs Windows, and I am using Putty and Filezilla to do management.
Just a side note: WinSCP IMHO is a lot easier to manage Linux servers than Filezilla (even though I used filezilla for decades.) I read the word "struggling"...
Have you restarted your server?
apache2ctl reload
or
service apache2 restart
I'll check it out!
I have :confused:
Have you cleaned up the config file as @rg305 suggested?
OMG!!
443/tcp filtered https
Gotta open 443 up to make it work!
Bet that's it!
curl -Ii https://reve.works
curl: (7) Failed to connect to reve.works port 443: No route to host
This is also interesting:
curl -Ii http://reve.works
HTTP/1.1 200 OK
Date: Thu, 08 Jun 2023 01:27:42 GMT
Server: Apache/2.4.52 (Ubuntu)
Link: <http://164.152.26.151/wp-json/>; rel="https://api.w.org/"
