I have a letsencrypt certificate for a domain, say example.com. I would like the cert to be for example.com and www.example.com. Is there a way to do a renewal or update to extend the existing cert?
assuming you are running certbot - try the --expand option on the command line. see https://certbot.eff.org/docs/using.html#re-running-certbot for details.
Don’t forget to include all the desired names in -d
options when doing this (-d example.com -d www.example.com
Thanks, that worked.
