Hello
I have uploaded key and fullchain files to my CDN. now if I renew my certificate, should I add the new cert and chain files to the CDN again?
Hello
The chain would most likely remain the same - when renewing from the same CA.
The public cert would change on renewal.
The chain will usually stay the same, but it may change at any time.
When issuing a new certificate, an automated Let’s Encrypt client should always check if the chain has changed and update it if necessary.
