Gitlab renewal issue
The IP of my domain is: 67.22.97.31
LE is resolving my domain to an old address: 67.22.96.146
My domain is: gitlab.aimphotonics.com
I ran this command: gitlab-ctl reconfigure
[2025-10-28T15:25:45+00:00] ERROR: Running exception handlers
[2025-10-28T15:25:45+00:00] ERROR: Exception handlers complete
[2025-10-28T15:25:45+00:00] FATAL: Stacktrace dumped to /opt/gitlab/embedded/cookbooks/cache/cinc-stacktrace.out
[2025-10-28T15:25:45+00:00] FATAL: ---------------------------------------------------------------------------------------
[2025-10-28T15:25:45+00:00] FATAL: PLEASE PROVIDE THE CONTENTS OF THE stacktrace.out FILE (above) IF YOU FILE A BUG REPORT
[2025-10-28T15:25:45+00:00] FATAL: RuntimeError: letsencrypt_certificate[gitlab.aimphotonics.com] (letsencrypt::http_authorization line 6) had an error: RuntimeError: acme_certificate[staging] (letsencrypt::http_authorization line 43) had an error: RuntimeError: ruby_block[create certificate for gitlab.aimphotonics.com] (letsencrypt::http_authorization line 110) had an error: RuntimeError: [gitlab.aimphotonics.com] Validation failed, unable to request certificate, Errors: [{url: https://acme-staging-v02.api.letsencrypt.org/acme/chall/238349543/19939886113/zydBkA, status: invalid, error: {"type"=>"urn:ietf:params:acme:error:connection", "detail"=>"67.22.96.146: Fetching http://gitlab.aimphotonics.com/.well-known/acme-challenge/2il1HiCwTcPM__yKMYUBuoiVlkEZLHnmNWLa2o_YtU4: Timeout during connect (likely firewall problem)", "status"=>400}} ]
root@gitlab:/var/log/gitlab/lets-encrypt# /opt/gitlab/embedded/sbin/nginx -version
nginx version: nginx/1.29.0
root@gitlab:/var/log/gitlab/lets-encrypt# uname -a
Linux gitlab.aimphotonics.com 5.15.0-161-generic #171-Ubuntu SMP Sat Oct 11 08:17:01 UTC 2025 x86_64 x86_64 x86_64 GNU/Linux
I can login to a root shell on my machine (yes or no, or I don't know): YES
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): NO
root@gitlab:/var/log/gitlab/lets-encrypt# certbot --version
certbot 5.1.0
When you ran that cert request had you just made the DNS change for the new IP?
Because I see the old IP in the Let's Encrypt staging system error message you posted. But, a current test using https://letsdebug.net shows the new IP. Other DNS tools all show the new IP too.
I am wondering if your DNS change just took a bit to synchronize across all your authoritative DNS servers.
Does this problem still occur?
DNS was changed last week, and had a TTL of 600
I just noticed the date. That was before you made the DNS change for the new IP. Right?
You know what....... You're right.
I'm going to go cut some eye-holes out of a brown paper bag.
Close ticket.
