Getssl: for some reason could not reach http://
I ran “getssl -d sede.cortesdepallas.es” with error “getssl: for some reason could not reach http://sede.cortesdepallas.es/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE - please check it manually”.
I can test http://sede.cortesdepallas.es/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE externally with no problem.
My domain is: sede.cortesdepallas.es
I ran this command: getssl -d sede.cortesdepallas.es
detected os type = linux
checking for required which ... /usr/bin/which
checking for required openssl ... /usr/bin/openssl
checking for required curl ... /usr/bin/curl
checking for nslookup ... /usr/bin/nslookup
function nslookup found at /usr/bin/nslookup  - setting DNS_CHECK_FUNC to nslookup
checking for required awk ... /usr/bin/awk
checking for required tr ... /usr/bin/tr
checking for required date ... /usr/bin/date
checking for required grep ... /usr/bin/grep
checking for required sed ... /usr/bin/sed
checking for required sort ... /usr/bin/sort
checking for required mktemp ... /usr/bin/mktemp
current code is version 2.10
Most recent version is  2.10
Making temp directory - /root/.getssl/sede.cortesdepallas.es/tmp
reading config from /root/.getssl/sede.cortesdepallas.es/getssl.cfg
checking config
checked ACCOUNT_KEY_TYPE
checked PRIVATE_KEY_ALG
checking domain sede.cortesdepallas.es
found IPv6 record for sede.cortesdepallas.es
sede.cortesdepallas.es: check_config completed  - all OK
getting certificate for sede.cortesdepallas.es from remote server
sede.cortesdepallas.es: no certificate obtained from host
Account key exists at /root/.getssl/account.key skipping generation
domain key exists at /root/.getssl/sede.cortesdepallas.es/sede.cortesdepallas.es.key - skipping generation
created SAN list = subjectAltName=DNS:sede.cortesdepallas.es
domain csr exists at - /root/.getssl/sede.cortesdepallas.es/sede.cortesdepallas.es.csr
jwk alg = RS256
jwk = {"e":"AQAB","kty":"RSA","n":"tPF98G-800ShlWIfayD5rG6fHVw-kotR9UB4wI20uMrlV-cbBwBhf4lB72OCuzlbGzGH_MeWEGVmBAENG-SHu9IS9IVjJA0ezQZhMCvCAAnbQ5HBC-0VoDwJUHQC-9Y9dzZ89hPrYCgdgdEuX_lfBvsCQoFNwTvhZuG6Lm2nSYsC0ExtduAGegsnRo7G3DWbh5Pkg6hwVlLI_g13018KedXQKsWsEqZso_IwmQHcHBYgsjaRe-Ip7AFgDP2YEBNCRCjZLQvboMuYHzt-kVsSRokZUlFDGi2ohkEkDHrvoNm2BzYaj2hzfrabnEZoM3wv2EGv1g1zNH5DOJLgGw13qGqaxUiHcUPdhhn4GYf1jpkyvJeJ5UyAEgvrvIeZ_T7JK-Qa8m5wPLa9mzl629cnEO0IipZ_k-TjYyZswlAkxK4eYPihNj7bcnY4n2ZkhL5qzC3jWBFZEm1g8Zo-y4mxnpK5oBJhqddKT7-lsAuUtxotVtFjYEbx9396zEOLSlYnYU4FT0Hz_THl9odQSOQGmCk4kjfmTIiJiIGLqPtoH12mxqzjqBGP92Wq0gdecljpmQIeIRM1o9EH3e4rCwSYx7GKAuWtNqiL4DMRHfoH8vXjf7JdBXMJkHo7orDReCV6SmGqtgzR6iaqvkE2otNyzGPGSWiaqEeR9-fsDFMbV0E"}
thumbprint kDq3PJukolrSTRYoWG67Z5KPLKgugUwyz3Y93pgEZHY
Registering account
url https://acme-v01.api.letsencrypt.org/acme/new-reg
payload {"resource": "new-reg", "agreement": "https://letsencrypt.org/documents/LE-SA-v1.2-November-15-2017.pdf"}
payload64 eyJyZXNvdXJjZSI6ICJuZXctcmVnIiwgImFncmVlbWVudCI6ICJodHRwczovL2xldHNlbmNyeXB0Lm9yZy9kb2N1bWVudHMvTEUtU0EtdjEuMi1Ob3ZlbWJlci0xNS0yMDE3LnBkZiJ9
nonce KdZI_2V4ppceLtLwRL6nJYMpNwtteHMkp8aZ9ztjVPY
protected {"alg": "RS256", "jwk": {"e":"AQAB","kty":"RSA","n":"tPF98G-800ShlWIfayD5rG6fHVw-kotR9UB4wI20uMrlV-cbBwBhf4lB72OCuzlbGzGH_MeWEGVmBAENG-SHu9IS9IVjJA0ezQZhMCvCAAnbQ5HBC-0VoDwJUHQC-9Y9dzZ89hPrYCgdgdEuX_lfBvsCQoFNwTvhZuG6Lm2nSYsC0ExtduAGegsnRo7G3DWbh5Pkg6hwVlLI_g13018KedXQKsWsEqZso_IwmQHcHBYgsjaRe-Ip7AFgDP2YEBNCRCjZLQvboMuYHzt-kVsSRokZUlFDGi2ohkEkDHrvoNm2BzYaj2hzfrabnEZoM3wv2EGv1g1zNH5DOJLgGw13qGqaxUiHcUPdhhn4GYf1jpkyvJeJ5UyAEgvrvIeZ_T7JK-Qa8m5wPLa9mzl629cnEO0IipZ_k-TjYyZswlAkxK4eYPihNj7bcnY4n2ZkhL5qzC3jWBFZEm1g8Zo-y4mxnpK5oBJhqddKT7-lsAuUtxotVtFjYEbx9396zEOLSlYnYU4FT0Hz_THl9odQSOQGmCk4kjfmTIiJiIGLqPtoH12mxqzjqBGP92Wq0gdecljpmQIeIRM1o9EH3e4rCwSYx7GKAuWtNqiL4DMRHfoH8vXjf7JdBXMJkHo7orDReCV6SmGqtgzR6iaqvkE2otNyzGPGSWiaqEeR9-fsDFMbV0E"}, "nonce": "KdZI_2V4ppceLtLwRL6nJYMpNwtteHMkp8aZ9ztjVPY", "url": "https://acme-v01.api.letsencrypt.org/acme/new-reg"}
header, payload and signature = {"header": {"alg": "RS256", "jwk": {"e":"AQAB","kty":"RSA","n":"tPF98G-800ShlWIfayD5rG6fHVw-kotR9UB4wI20uMrlV-cbBwBhf4lB72OCuzlbGzGH_MeWEGVmBAENG-SHu9IS9IVjJA0ezQZhMCvCAAnbQ5HBC-0VoDwJUHQC-9Y9dzZ89hPrYCgdgdEuX_lfBvsCQoFNwTvhZuG6Lm2nSYsC0ExtduAGegsnRo7G3DWbh5Pkg6hwVlLI_g13018KedXQKsWsEqZso_IwmQHcHBYgsjaRe-Ip7AFgDP2YEBNCRCjZLQvboMuYHzt-kVsSRokZUlFDGi2ohkEkDHrvoNm2BzYaj2hzfrabnEZoM3wv2EGv1g1zNH5DOJLgGw13qGqaxUiHcUPdhhn4GYf1jpkyvJeJ5UyAEgvrvIeZ_T7JK-Qa8m5wPLa9mzl629cnEO0IipZ_k-TjYyZswlAkxK4eYPihNj7bcnY4n2ZkhL5qzC3jWBFZEm1g8Zo-y4mxnpK5oBJhqddKT7-lsAuUtxotVtFjYEbx9396zEOLSlYnYU4FT0Hz_THl9odQSOQGmCk4kjfmTIiJiIGLqPtoH12mxqzjqBGP92Wq0gdecljpmQIeIRM1o9EH3e4rCwSYx7GKAuWtNqiL4DMRHfoH8vXjf7JdBXMJkHo7orDReCV6SmGqtgzR6iaqvkE2otNyzGPGSWiaqEeR9-fsDFMbV0E"}},"protected": "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","payload": "eyJyZXNvdXJjZSI6ICJuZXctcmVnIiwgImFncmVlbWVudCI6ICJodHRwczovL2xldHNlbmNyeXB0Lm9yZy9kb2N1bWVudHMvTEUtU0EtdjEuMi1Ob3ZlbWJlci0xNS0yMDE3LnBkZiJ9","signature": "g0gGo6huoxUWI6fIiTLJOh8tQ9A8us4vqMz2wKu4OOZHwP_eA2HPFy5RA1neb3HpQYKjaCRgK0dVRITp9eSr0hR7QYxZafjrISBHgO_7Xpg2tZ5LhDnd06C8agyvf4tNGMZZkTS1GjOA07iRaSB9GhdAZcCOE-2jlBfBjPz9VaNuMaVY6BdU5PTJmrldq3dhGXbSPWzqrXmnKzOuvH0Suq1ZzY2pTEjQK1vLGBmz6W0JphlRQlXe-AT8J2pW8Hfio9hpx4IBlxrGd6lR3Q7ZE0yeM-dvtYnlJJrpRxO-FC7Vu7ULxaK893F1fskS4tyuEV_VqdtZukLBP8hNoeNGL-KkQ2sTifl04uJLIEL7FaqysHbJHwrc_gW-WuCDWbVlz5UjoxAsd6klAF03FR8CZa0cj3P1cRa_QtqpZjc2vxOJM_B-bjYM3IZyYWaDAiWS2O830v0wcdwrVP1v--ReCyMEMDoKAlyOTll2mZTE-s4isUZl6QP-utNd9CXcWo6l-El7eZNFzasrWJqsbt8MlkIQIA9BBi_gpafVinICW2Zs3tnjURwAusEUmp2tkQqhpMc-p2__IJsgrAlp72_Ijn1DBBX3cOAwjwf6VTGBdZGWxUBEDcVXs8wswnppnk4idcTRoMPqViQDYruJ7_4Lgfq4ih_vVOKoqyJuj49hgtE"}
responseHeaders HTTP/1.1 100 Continue
Expires: Wed, 10 Oct 2018 10:59:49 GMT
Cache-Control: max-age=0, no-cache, no-store
Pragma: no-cache
HTTP/1.1 409 Conflict
Server: nginx
Content-Type: application/problem+json
Content-Length: 107
Boulder-Requester: 43490846
Location: https://acme-v01.api.letsencrypt.org/acme/reg/43490846
Replay-Nonce: E5VPeQNHXm-WuLlVsI8VVO14oPOmU1wQnMDFBOkP54s
Pragma: no-cache
Date: Wed, 10 Oct 2018 10:59:49 GMT
Connection: close
response {
  "type": "urn:acme:error:malformed",
  "detail": "Registration key is already in use",
  "status": 409
code 409
response status =
Already registered
Verify each domain
Verifying sede.cortesdepallas.es
url https://acme-v01.api.letsencrypt.org/acme/new-authz
payload {"resource":"new-authz","identifier":{"type":"dns","value":"sede.cortesdepallas.es"}}
payload64 eyJyZXNvdXJjZSI6Im5ldy1hdXRoeiIsImlkZW50aWZpZXIiOnsidHlwZSI6ImRucyIsInZhbHVlIjoic2VkZS5jb3J0ZXNkZXBhbGxhcy5lcyJ9fQ
nonce CIY7JTxrkuVpegmPN-ZQpiSL7k5YJERxu240sDUDtZs
protected {"alg": "RS256", "jwk": {"e":"AQAB","kty":"RSA","n":"tPF98G-800ShlWIfayD5rG6fHVw-kotR9UB4wI20uMrlV-cbBwBhf4lB72OCuzlbGzGH_MeWEGVmBAENG-SHu9IS9IVjJA0ezQZhMCvCAAnbQ5HBC-0VoDwJUHQC-9Y9dzZ89hPrYCgdgdEuX_lfBvsCQoFNwTvhZuG6Lm2nSYsC0ExtduAGegsnRo7G3DWbh5Pkg6hwVlLI_g13018KedXQKsWsEqZso_IwmQHcHBYgsjaRe-Ip7AFgDP2YEBNCRCjZLQvboMuYHzt-kVsSRokZUlFDGi2ohkEkDHrvoNm2BzYaj2hzfrabnEZoM3wv2EGv1g1zNH5DOJLgGw13qGqaxUiHcUPdhhn4GYf1jpkyvJeJ5UyAEgvrvIeZ_T7JK-Qa8m5wPLa9mzl629cnEO0IipZ_k-TjYyZswlAkxK4eYPihNj7bcnY4n2ZkhL5qzC3jWBFZEm1g8Zo-y4mxnpK5oBJhqddKT7-lsAuUtxotVtFjYEbx9396zEOLSlYnYU4FT0Hz_THl9odQSOQGmCk4kjfmTIiJiIGLqPtoH12mxqzjqBGP92Wq0gdecljpmQIeIRM1o9EH3e4rCwSYx7GKAuWtNqiL4DMRHfoH8vXjf7JdBXMJkHo7orDReCV6SmGqtgzR6iaqvkE2otNyzGPGSWiaqEeR9-fsDFMbV0E"}, "nonce": "CIY7JTxrkuVpegmPN-ZQpiSL7k5YJERxu240sDUDtZs", "url": "https://acme-v01.api.letsencrypt.org/acme/new-authz"}
header, payload and signature = {"header": {"alg": "RS256", "jwk": {"e":"AQAB","kty":"RSA","n":"tPF98G-800ShlWIfayD5rG6fHVw-kotR9UB4wI20uMrlV-cbBwBhf4lB72OCuzlbGzGH_MeWEGVmBAENG-SHu9IS9IVjJA0ezQZhMCvCAAnbQ5HBC-0VoDwJUHQC-9Y9dzZ89hPrYCgdgdEuX_lfBvsCQoFNwTvhZuG6Lm2nSYsC0ExtduAGegsnRo7G3DWbh5Pkg6hwVlLI_g13018KedXQKsWsEqZso_IwmQHcHBYgsjaRe-Ip7AFgDP2YEBNCRCjZLQvboMuYHzt-kVsSRokZUlFDGi2ohkEkDHrvoNm2BzYaj2hzfrabnEZoM3wv2EGv1g1zNH5DOJLgGw13qGqaxUiHcUPdhhn4GYf1jpkyvJeJ5UyAEgvrvIeZ_T7JK-Qa8m5wPLa9mzl629cnEO0IipZ_k-TjYyZswlAkxK4eYPihNj7bcnY4n2ZkhL5qzC3jWBFZEm1g8Zo-y4mxnpK5oBJhqddKT7-lsAuUtxotVtFjYEbx9396zEOLSlYnYU4FT0Hz_THl9odQSOQGmCk4kjfmTIiJiIGLqPtoH12mxqzjqBGP92Wq0gdecljpmQIeIRM1o9EH3e4rCwSYx7GKAuWtNqiL4DMRHfoH8vXjf7JdBXMJkHo7orDReCV6SmGqtgzR6iaqvkE2otNyzGPGSWiaqEeR9-fsDFMbV0E"}},"protected": "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","payload": "eyJyZXNvdXJjZSI6Im5ldy1hdXRoeiIsImlkZW50aWZpZXIiOnsidHlwZSI6ImRucyIsInZhbHVlIjoic2VkZS5jb3J0ZXNkZXBhbGxhcy5lcyJ9fQ","signature": "DHtGq5Oot3rs5heCkJ7DdvkaMURIYSMqk_CW7armbfvBXEVPXN_UT8ZWtarIemwBALCjZcrNpXtBIOgCpu27Da3CmetWauJkUCxfAowejOqEQQ0c_2sMAuuky7JirwXyeejCLdbozOb7lq0IV0NNTQkJKzVJvKwPWWsN2JCBsCmpSNr0xXKA5hVCFZW0x1kiBuJyqn4oYKmTsGsNgdJMghsRr1VrFdZA0bDuAhg9GL47gonuSudgQxQJ6t7YxyWfHESkopkRMYXMTgvFO6S2WJmRjhXrEb_7qVdMcj93XkymkfuyMK3PiOH_OkapqAmJVQrEuCiYjtRIqwu6WTcfoO-hkTtluSxbJalzzaQF8w4r16cmeIIPHgB9lf_F2WlJoJeFxkM4Jg0DTmsgPFOBukfAoFpct0Wf2k3901sgY_wa-F-uEIJeBhJc47CZezxsNkgCHXWgeP6exFhmG8Zfs35NGKt-n5bS_ml8xugdzuRFAVDAHuPLClr3Gu0AF7MxSf9iqMJ31vGwEIp2DAfvWfsRfsvj0LWZYDYAmy0gtHpHltzpwaWZ4BxntHQ7B2lWyx4UaA8pKwgthLs0EiZKLnGoS6I27wq6uen7XXjMmAtDWuiVDH8dnehuaYWNETU1iOP63r_47qUUg8ouVx201SWjROPVWmBuXCU0-zy9FEo"}
Expires: Wed, 10 Oct 2018 10:59:50 GMT
Pragma: no-cache
HTTP/1.1 201 Created
Server: nginx
Content-Length: 1001
Link: <https://acme-v01.api.letsencrypt.org/acme/new-cert>;rel="next"
Location: https://acme-v01.api.letsencrypt.org/acme/authz/C6HBpBoWr3Xxse5NgrVZLu5hHyP2MkjJtcBzBwuxFg4
Replay-Nonce: wYPqlD05vHTGXgqy0NtAP-oQWKHb9VDpbMKO6dK3kXs
X-Frame-Options: DENY
Expires: Wed, 10 Oct 2018 10:59:51 GMT
Pragma: no-cache
Date: Wed, 10 Oct 2018 10:59:51 GMT
response {
  "identifier": {
    "type": "dns",
    "value": "sede.cortesdepallas.es"
  "status": "pending",
  "expires": "2018-10-15T14:42:12Z",
  "challenges": [
      "type": "tls-alpn-01",
      "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/C6HBpBoWr3Xxse5NgrVZLu5hHyP2MkjJtcBzBwuxFg4/8062604781",
      "token": "AyrjTTjDI1YUYNuwGhkMa11lbAXjGfuBMP6l5macE24"
      "type": "http-01",
      "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/C6HBpBoWr3Xxse5NgrVZLu5hHyP2MkjJtcBzBwuxFg4/8062604782",
      "token": "hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE"
      "type": "dns-01",
      "uri": "https://acme-v01.api.letsencrypt.org/acme/challenge/C6HBpBoWr3Xxse5NgrVZLu5hHyP2MkjJtcBzBwuxFg4/8062604783",
      "token": "wKU0ugyZ3WNxRt364dPBXJhoNwft0YqqlEe6NL9Nqa8"
  "combinations": [
      1
      2
      0
code 201
response status = pending
completed send_signed_request
token hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE
uri https://acme-v01.api.letsencrypt.org/acme/challenge/C6HBpBoWr3Xxse5NgrVZLu5hHyP2MkjJtcBzBwuxFg4/8062604782
keyauthorization hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE.kDq3PJukolrSTRYoWG67Z5KPLKgugUwyz3Y93pgEZHY
copying file from /root/.getssl/sede.cortesdepallas.es/tmp/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE to /opt/apache-tomcat-9.0.10/webapps/.well-known/acme-challenge
copying challenge token to /opt/apache-tomcat-9.0.10/webapps/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE
copying from /root/.getssl/sede.cortesdepallas.es/tmp/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE to /opt/apache-tomcat-9.0.10/webapps/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE
copied /root/.getssl/sede.cortesdepallas.es/tmp/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE to /opt/apache-tomcat-9.0.10/webapps/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE
wellknown_url http://sede.cortesdepallas.es/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE
My web server is (include version): Apache Tomcat 9.0.10
The operating system my web server runs on is (include version): openSUSE 42.2 (x86_64)
My hosting provider, if applicable, is: -
It seems that you have a software block /firewall block on the port 80 when visitors viewing your website outside (your internal Network)
Let’s encrypt need to connect to your servers port 80 and validate security tokens (challenge files) before issue a certificate. (Via HTTP-01)
Thank you
Hi.
No. I checked it. And also I can access http://sede.cortesdepallas.es/.well-known/acme-challenge/hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE from LAN’s outside. For example, from my mobile. The response is “hXsE2BPaDK68CiYn6X0b2Odq0X5frSuZPHcBnKlbTSE.kDq3PJukolrSTRYoWG67Z5KPLKgugUwyz3Y93pgEZHY”.
Thanks
Hi @lpascual,
This error is coming from your ACME client (getssl) and not the Let's Encrypt validation server. I believe the client is doing its own "pre-check" and isn't satisfied for some reason. Can you verify that you're able to access the URL checking from the server running getssl?
Hi @lpascual
Letsdebug isn't happy:
Bad Redirects using ipv6 and different answers using ipv4 and ipv6.
Now the letsdebug’s response is OK, but getssl returns the same error.
Did you see my earlier reply? Can you verify that you’re able to access the URL checking from the server running getssl?
Sorry. I didn’t see it. But finally, I used certbot, and generate the certificate successfully.
Thanks!!
