Get the ssl certificate successfully but it does not work
My domain is: urbatis.net
I ran this command: sudo certbot certonly --webroot -w ~/smart_city/smart_city -d urbatis.net
It produced this output: IMPORTANT NOTES:
    /etc/letsencrypt/live/urbatis.net/fullchain.pem
    /etc/letsencrypt/live/urbatis.net/privkey.pem
    Your cert will expire on 2019-08-26. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    “certbot renew”
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
My web server is (include version): Unix
The operating system my web server runs on is (include version): Ubuntu 16.04 xenial
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
I can’t reach my page by https://urbatis.net.
Hi @ishidaira233,
Please see these prior threads about the meaning of certonly:
https://community.letsencrypt.org/search?q=certonly%20means
Thank you for your reply! It’s the problem. But I retried by “sudo certbot --apache” and to reinstall this existing certificate so I don’t need to write configuration file. This time the message is :Congratulations! You have successfully enabled https://urbatis.net
https://www.ssllabs.com/ssltest/analyze.html?d=urbatis.net
    /etc/letsencrypt/live/urbatis.net-0001/fullchain.pem
    /etc/letsencrypt/live/urbatis.net-0001/privkey.pem
    with the “certonly” option. To non-interactively renew all of
    your certificates, run “certbot renew”
But I still can’t reach my site by https.
Hi @ishidaira233
your site is completely invisible ( https://check-your-website.server-daten.de/?q=urbatis.net ):
• http://urbatis.net/
217.182.139.143 -14 10.030 T
Timeout - The operation has timed out
• http://www.urbatis.net/
• https://urbatis.net/
• https://www.urbatis.net/
217.182.139.143 -14 10.026 T
• http://urbatis.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Visible Content:
• http://www.urbatis.net/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
Visible Content:
Only timeouts.
Is there a firewall? Or a missing router forwarding?
Works your site intern? Test from your webserver:
curl http://urbatis.net/
curl https://urbatis.net/
curl http://217.182.139.143/
curl https://217.182.139.143/
Same with your ip address - https://check-your-website.server-daten.de/?q=217.182.139.143
Thank you for your reply. Now it visible, I just encountered some problems with my apache service.
Yep, now there is a new check - https://check-your-website.server-daten.de/?q=urbatis.net
http works, https has a timeout.
What says
apachectl configtest
apachectl fullstatus
apachectl -S
I need to add sudo to run these commands. And here is the results:
sudo apachectl configtest
Syntax OK
sudo apachectl fullstatus
/usr/sbin/apachectl: line 101: www-browser: command not found
'www-browser -dump http://localhost:80/server-status' failed.
sudo apachectl -S
VirtualHost configuration:
*:443 urbatis.net (/etc/apache2/sites-enabled/000-default-le-ssl.conf:2)
*:80 ns3079645.ip-217-182-139.eu (/etc/apache2/sites-enabled/000-default.conf:1)
ServerRoot: "/etc/apache2"
Mutex default: dir="/var/lock/apache2" mechanism=fcntl
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
What's the content of that file:
And works https internal?
Content of /etc/apache2/sites-enabled/000-default-le-ssl.conf :
    # error, crit, alert, emerg.
    # modules, e.g.
    #LogLevel info ssl:warn
    ServerName urbatis.net
    ServerAlias www.urbatis.net
    SSLCertificateFile /etc/letsencrypt/live/www.urbatis.net/fullchain.pem
    SSLCertificateKeyFile /etc/letsencrypt/live/www.urbatis.net/privkey.pem
    </VirtualHost>
    </IfModule>
https internal doesn’t work, it tells “Failed to connect to 217.182.139.143 port 443: Connection refused” and “Failed to connect to urbatis.net port 443: Connection refused”
Your files are wrong:
These are your new files - add -0001
I correct that. Now it’s match :
  SSLCertificateFile /etc/letsencrypt/live/urbatis.net-0001/fullchain.pem
  SSLCertificateKeyFile /etc/letsencrypt/live/urbatis.net-0001/privkey.pem
  </VirtualHost>
  </IfModule>
Should I do something else? It shows no certificates at https://check-your-website.server-daten.de/?q=urbatis.net
Same question:
Does it now work internal? If you see a connection refused, but https://check-your-website.server-daten.de/?q=urbatis.net shows a timeout, there are two different problems:
  • https must work internal (perhaps fixed with urbatis.net-0001)
  • there is a firewall or something else, that blocks, so the online tool doesn't see the connection refused, instead a timeout
It doesn’t work internal, which is still “Failed to connect to 217.182.139.143 port 443: Connection refused” and “Failed to connect to urbatis.net port 443: Connection refused”
Did you restart the server?
What says your error log?
I find I have three certificates for my site:
Found the following certs:
Certificate Name: ns3079645.ip-217-182-139.eu
Domains: ns3079645.ip-217-182-139.eu
Expiry Date: 2018-09-17 08:51:52+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/ns3079645.ip-217-182-139.eu/fullchain.pem
Private Key Path: /etc/letsencrypt/live/ns3079645.ip-217-182-139.eu/privkey.pem
Certificate Name: urbatis.net-0001
Domains: urbatis.net
Expiry Date: 2019-08-26 12:26:40+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/urbatis.net-0001/fullchain.pem
Private Key Path: /etc/letsencrypt/live/urbatis.net-0001/privkey.pem
Domains: www.urbatis.net urbatis.net
Expiry Date: 2019-08-26 09:19:47+00:00 (VALID: 88 days)
Certificate Path: /etc/letsencrypt/live/urbatis.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/urbatis.net/privkey.pem
Certificate Name: www.urbatis.net
Expiry Date: 2019-08-26 12:29:55+00:00 (VALID: 89 days)
Certificate Path: /etc/letsencrypt/live/www.urbatis.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.urbatis.net/privkey.pem
I don't if it's the problem, and I have restarted the server.
There is nothing in /var/log/apache2/error.log...
Thank you for your help and patience!
