It seems to be working, but each time it initiates a new https connection to api.linode.com certbot will hang for 393 seconds prior to the next log entry.
To see if the issue may be in the linode side, I hit api.linode.com with curl to retrieve the domain list (curl -H "Authorization: Bearer $TOKEN" https://api.linode.com/v4/domains) and received an immediate response. So the fault does not seem to be with the linode servers.
notthisone.net seanmb.com
certbot certonly --dns-linode
--dns-linode-credentials ~/.secrets/certbot/linode.ini
--dns-linode-propagation-seconds 120
-d notthisone.net -d "*.notthisone.net"
-d seanmb.com -d "*.seanmb.com"
So far (over and hour and has not completed)
From command line:
Requesting a certificate for notthisone.net and 3 more domains
Contents of /var/log/letsencrypt/letsencrypt.log
root@main:/etc/nginx/conf.d# tail -f /var/log/letsencrypt/letsencrypt.log
2022-11-28 05:31:33,707:DEBUG:acme.client:Storing nonce: 891Fq2BnDrDjgF8D-pxkRQJl2bHnzWOPPS_k5UVcgEFaHdk
2022-11-28 05:31:33,707:INFO:certbot._internal.auth_handler:Performing the following challenges:
2022-11-28 05:31:33,707:INFO:certbot._internal.auth_handler:dns-01 challenge for notthisone.net
2022-11-28 05:31:33,707:INFO:certbot._internal.auth_handler:dns-01 challenge for seanmb.com
2022-11-28 05:31:33,708:INFO:certbot._internal.auth_handler:dns-01 challenge for notthisone.net
2022-11-28 05:31:33,708:INFO:certbot._internal.auth_handler:dns-01 challenge for seanmb.com
2022-11-28 05:31:33,708:WARNING:certbot.plugins.dns_common:Unsafe permissions on credentials configuration file: /root/.secrets/certbot/linode.ini
2022-11-28 05:31:33,711:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 05:38:06,028:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains HTTP/1.1" 200 408
2022-11-28 05:38:06,031:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 05:44:39,242:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains/10793/records HTTP/1.1" 200 1012
2022-11-28 05:44:39,243:DEBUG:lexicon.providers.linode4:list_records:
2022-11-28 05:44:39,244:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 05:51:12,514:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "POST /v4/domains/10793/records HTTP/1.1" 200 284
2022-11-28 05:51:12,523:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 05:57:45,674:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains HTTP/1.1" 200 392
2022-11-28 05:57:45,676:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:04:18,887:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains/744840/records HTTP/1.1" 200 1016
2022-11-28 06:04:18,889:DEBUG:lexicon.providers.linode4:list_records:
2022-11-28 06:04:18,891:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:10:52,152:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "POST /v4/domains/744840/records HTTP/1.1" 200 284
2022-11-28 06:10:52,155:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:17:25,324:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains HTTP/1.1" 200 408
2022-11-28 06:17:25,326:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:23:58,532:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains/10793/records HTTP/1.1" 200 None
2022-11-28 06:23:58,534:DEBUG:lexicon.providers.linode4:list_records:
2022-11-28 06:23:58,535:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:30:31,822:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "POST /v4/domains/10793/records HTTP/1.1" 200 284
2022-11-28 06:30:31,828:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:37:04,974:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains HTTP/1.1" 200 392
2022-11-28 06:37:04,977:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
2022-11-28 06:43:38,180:DEBUG:urllib3.connectionpool:https://api.linode.com:443 "GET /v4/domains/744840/records HTTP/1.1" 200 None
2022-11-28 06:43:38,181:DEBUG:lexicon.providers.linode4:list_records:
2022-11-28 06:43:38,182:DEBUG:urllib3.connectionpool:Starting new HTTPS connection (1): api.linode.com:443
nginx version: nginx/1.14.2
built with OpenSSL 1.1.1n 15 Mar 2022
Debian 10
linode (VPS)
Yes
No
certbot 1.32.0
Pluging certbot-dns-linode 2.1.0
