Generate key on Linux for manual use on Azure
My domain is:www.hardcoregames.biz
I ran this command:openssl …
It produced this output:key.cer or key.pfm
What exactly is your question? You need a key? Let’s Encrypt doesn’t provide keys. It provides publically valid PKI certificates for TLS servers.
Really?
openssl …
That doesn't tell us anything.
OR?
That also tells us nothing.
And the title
" Generate key on Linux for manual use on Azure "
Also says little about what the problem is and what you are trying to do.
