Hello,
After changed hosting provider where I didn't have this problem (using systemd)...
Problem:
Using Docker, just the time to take down my webserver container to update a certificate...
When I try to launch a certificate update by shell I receive the error "can't set attribute error".
Possible cause:
I realized to have forgotten in place the cron job of scheduled cert renew by "certbot -q renew".
Indeed my log is full of pending requests with "too many requests error" and "can't set attribute error"
From 20231214 03:44 and before with an "Address already is use" error (due to docker)
What is happend is exactly this:
- I took down my docker webserver container
- I did to update the certificate with a new subdomain of 5mode "certbot certonly --cert-name 5mode -d 5mode.com, www.5mode.com, bot.5mode.com
- I got the error "can't set attribute" (coming as letter one)
Given: Rate Limits - Let's Encrypt
I would like to ask is it possible to clear my Pending Authorization Requests to let me work
again over my domains?
Indeed what could be the possible solutions to circumvent the limit problem arrived at the
1st gen 2024 when my certificates will start to expire if the situation gets not solved before?
And are we sure we all need this cron job automatically installed?
Thanks,
== Daniele Bonini
various, eg. 5mode.com
submitting a "certbot certonly --cert-name 5mode.com -d etc."
wiz# tail -n40 /var/log/letsencrypt/letsencrypt.log
File "/usr/lib/python3/dist-packages/certbot/_internal/client.py", line 478, in _get_order_and_authorizations
orderr = self.acme.new_order(csr_pem)
File "/usr/lib/python3/dist-packages/acme/client.py", line 138, in new_order
response = self._post(self.directory['newOrder'], order)
File "/usr/lib/python3/dist-packages/acme/client.py", line 338, in _post
return self.net.post(*args, **kwargs)
File "/usr/lib/python3/dist-packages/acme/client.py", line 711, in post
return self._post_once(*args, **kwargs)
File "/usr/lib/python3/dist-packages/acme/client.py", line 724, in _post_once
response = self._check_response(response, content_type=content_type)
File "/usr/lib/python3/dist-packages/acme/client.py", line 575, in _check_response
raise messages.Error.from_json(jobj)
acme.messages.Error: urn:ietf:params:acme:error:rateLimited :: There were too many requests of a given type :: Error creating new order :: too many currently pending authorizations: 302: see Rate Limits - Let's Encrypt
File "/usr/bin/certbot", line 33, in
sys.exit(load_entry_point('certbot==2.1.0', 'console_scripts', 'certbot')())
File "/usr/lib/python3/dist-packages/certbot/main.py", line 19, in main
File "/usr/lib/python3/dist-packages/certbot/_internal/main.py", line 1733, in main
with make_displayer(config) as displayer:
File "/usr/lib/python3.11/contextlib.py", line 188, in exit
exc.traceback = traceback
File "/usr/lib/python3/dist-packages/josepy/util.py", line 191, in setattr
raise AttributeError("can't set attribute")
AttributeError: can't set attribute
2023-12-14 07:36:14,791:ERROR:certbot._internal.log:An unexpected error occurred:
2023-12-14 07:36:14,793:ERROR:certbot._internal.log:AttributeError: can't set attribute
doesn't matter, it is under docker..
Debian 11
Hetzner
Boh!
Boh!
certbot 2.1.0
