I'm having difficulties running certbot renewals via cronjob in one particular environment. I have two other environments that the cronjob renewals run fine. Only in this one have I received problems. If I set the cronjob a few minutes or hours ahead, it typically runs fine. If I set it to run a week ahead, I run into the issue I describe below.
My domain is: dev.elselabs.io
I run a CRONTAB which runs this script:
echo "\n BEGINNING REFRESH \n";
# Print the current date and time
dt=$(date '+%d/%m/%Y %H:%M:%S');
echo "$dt"
# Request a Lets Encrypt certificate using the offical Docker image
# for provided domain
DOMAIN=$1;
echo "\n\033[0;33m=> Requesting CERT for $DOMAIN ------------------------------\033[0";
docker run --name certbot -v /etc/letsencrypt:/etc/letsencrypt -v /var/www/html:/var/www/html certbot/certbot certonly \
--webroot --webroot-path=/var/www/html -d $DOMAIN --force-renewal --verbose
# GET Nginx docker container name, then stop and remove it
# The automatically generated Nginx container will apply the new CERT
CONTAINER_NAME=$(exec docker ps --format "{{.Names}}" | grep nginx);
echo "\n\033[0;33m=> Stopping $CONTAINER_NAME ------------------------------\033[0m";
docker stop $CONTAINER_NAME
echo "\n\033[0;33m=> Removing $CONTAINER_NAME ------------------------------\033[0m";
docker rm $CONTAINER_NAME;
echo "\n REFRESH COMPLETE \n";
The CRONTAB looks like this:
0 0 * * FRI /usr/src/nginx/refresh_cert.sh dev.elselabs.io >> /usr/src/nginx/refresh_cert.err
When the command is run from the terminal, it looks like this:
02/02/2024 15:19:07
\n\033[0;33m=> Requesting CERT for dev.elselabs.io ------------------------------\033[0
Renewing an existing certificate for dev.elselabs.io
Certificate is saved at: /etc/letsencrypt/live/dev.elselabs.io/fullchain.pem
Key is saved at: /etc/letsencrypt/live/dev.elselabs.io/privkey.pem
This certificate expires on 2024-05-02.
NEXT STEPS:
- The certificate will need to be renewed before it expires. Certbot can automatically renew the certificate in the background, but you may need to take steps to enable that functionality. See https://certbot.org/renewal-setup for instructions.
* Donating to ISRG / Let's Encrypt: https://letsencrypt.org/donate
* Donating to EFF: https://eff.org/donate-le
\n\033[0;33m=> Stopping development_nginx.1.zq9ajwgosjmzxwp9if1xkswqn ------------------------------\033[0m
\n\033[0;33m=> Removing development_nginx.1.zq9ajwgosjmzxwp9if1xkswqn ------------------------------\033[0m
When the crontab runs it, it looks like this:
02/02/2024 00:00:01
\n\033[0;33m=> Stopping development_nginx.1.3al3392m9fjk44nzgb5dwcifi ------------------------------\033[0m
\n\033[0;33m=> Removing development_nginx.1.3al3392m9fjk44nzgb5dwcifi ------------------------------\033[0m
I allowed the container to remain on the server so I could inspect the logs within it. They look like this:
An unexpected error occurred:
No order for ID 241139202797
I'm running NGINX in a container. nginx:stable-alpine
I'm running this on Ubuntu 22.
This infrastructure runs within a DigitalOcean droplet
Yes
No.
I should be running the latest certbot dockerhub image.
