Flask SSL Configuration while using Nginx
My domain is: devamsizliktakip.com
I ran this command: sudo certbot certonly --nginx
We recommend selecting either all domains, or all domains in a VirtualHost/server block.
1: devamsizliktakip.info.tr
2: www.devamsizliktakip.info.tr
Requesting a certificate for devamsizliktakip.info.tr and www.devamsizliktakip.info.tr
Domain: devamsizliktakip.info.tr
Detail: 31.223.116.176: Invalid response from http://devamsizliktakip.info.tr/.well-known/acme-challenge/u0Os7z65nEfi5LCPw38fqnmJ0ISxzDWGajpk7qgSqYU: 404
Domain: www.devamsizliktakip.info.tr
Detail: 31.223.116.176: Invalid response from http://www.devamsizliktakip.info.tr/.well-known/acme-challenge/sXrltsW9lLugk-dxchgUt45MpC4i5x_f7m4GeJ-kYCs: 404
My web server is (include version): Python Flask app deployed with waitress
The operating system my web server runs on is (include version): Debian GNU/Linux 12 (bookworm) (virtualbox)
My hosting provider, if applicable, is: I don't think this matters. It successfully redirects.
I can login to a root shell on my machine (yes or no, or I don't know): I am able to execute commands in terminal with root access if this is what is being asked.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): I dont use
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 3.2.0 (I am unable to use)
Things that i feel i should mention:
I can access my website from my mobile phone.
Some friend of mine can not reach while some can.
If i use http:// , I can reach while https:// returns error.
I think this http(s):// situation causes this
That's why i am trying to get SSL certificate
The --nginx option only works when an nginx server replies to HTTP requests.
I see your waitress server replying. You should use the --webroot method instead. See: User Guide — Certbot 4.0.0.dev0 documentation
Does this sound like a solution to your problem?
