First time making an https server and stuck at figuring out why it's failing these challenges of creating them and using them to verify my server
My domain is: noskc.com
1: noskc.com
2: www.noskc.com
*blank to select all options shown (Enter 'c' to cancel): *
Requesting a certificate for noskc.com and www.noskc.com
Apache/2.4.52
Ubuntu 22.04
no
certbot 1.21.0
That's a very old version of certbot (current is 2.80), but that probably isn't what's causing your problem. What I'm noticing is that noskc.com and www.noskc.com are resolving to different IP addresses. And if I dig a little further, I see that both IP addresses belong to noskc.com. Checking a bit futher, it appears they both serve a redirect to http://173.18.238.44/ This isn't going to work; you'll need to correct your DNS entries to point to your actual IP address.
AND...
A redirect changes the URL [in your address bar].
So, a redirect to: http://173.18.238.44/
Makes your request turn into HTTP [and to an IP - not a name].
[one is forcibly insecure, the other can't be secured via an LE cert]
Here is what I see for DNS:
Let’s Encrypt offers Domain Validation (DV) certificates; and not IP Addresses.
And https://letsdebug.net/noskc.com/1784050 shows
MultipleIPAddressDiscrepancy
WARNING
noskc.com has multiple IP addresses in its DNS records. While they appear to be accessible on the network, we have detected that they produce differing results when sent an ACME HTTP validation request. This may indicate that some of the IP addresses may unintentionally point to different servers, which would cause validation to fail.
[Address=3.33.152.147,Address Type=IPv4,Server=ip-10-123-123-186.ec2.internal,HTTP Status=404] vs [Address=15.197.142.173,Address Type=IPv4,Server=ip-10-123-122-53.ec2.internal,HTTP Status=404]
This looks like you are using a GoDaddy hosting service? Yes?
If so, you have their URL Redirect setup. You need to disable that and setup a DNS A record pointing directly to the public IP of your Apache server.
That helped a bit with learning that GoDaddy's URL Redirect was needing to be turned off. Thanks for that info.
With me correcting my DNS entries to point to my actual IP address does that mean disabling the goDaddy url redirect? I thought I was pointing it to the right ip address, but if I'm not then do I do that from the router specifically or do I need to go through the terminal to set the ip address?
So I am forcing it to redirect into an http? Is that only because of goDaddy or something else I'm missing?
That was all Godaddy.
Check your actual IP:
  • curl -4 ifconfig.me
  • web search "What Is My IP?"
With what is found in global DNS:
  • nslookup noskc.com
  • nslookup www.noskc.com
If they match, then continue with obtaining a cert.
If they don't match, stop and update the global DNS zone.
@SilverKnight317 Just checking in and note this is definitely not your public IP :slight_smile: Be sure to follow guide in previous post by @rg305
noskc.com.     1800    IN      A       127.0.0.53
yeah, lol, I don't know why the heck I typed that and have just corrected it!
Okay! I got the certification and just need to make sure the cert is applied. Thanks guys!
