SOME CHALLENGES HAVE FAILED /// pls help
Requesting a certificate for (sitename)
http-01 challenge for (sitename)
Enabled Apache rewrite module
Challenge failed for domain (sitename)
Domain: (sitename)
Detail: 3.33.152.147: Invalid response from http://(sitename)/.well-known/acme-challenge/(key): 404
Is that really your IP? Because it looks like a URL Rewrite or URL Forwarding service and not a normal DNS A record. I say that because it is for AWS Global Accelerator and many hosting providers use that for such a purpose (like GoDaddy)
Nobody can really help you without some basic information like your domain.
For http validation to work your server running certbot needs to respond to the HTTP challenge, and if you are using something exotic like an AWS load balancer (we're guessing based on the IP address shown) then all the responding hosts need to be able to respond to the challenge with the same reply.
Hi @Vitaly123, and welcome to the LE community forum :slight_smile:
If that is your IP address, I would start by reviewing the output of:
sudo apachectl -t -D DUMP_VHOSTS
And in all cases, I would fill out the questionaire that you should have been presented with when choosing "HELP":
[feel free to translate it into your preferred language]
ye, i use godaddy
its not my ip
You need to change your DNS config so it has an A record for your public IP. You will need to disable the GoDaddy URL Redirect / Forwarding service to do this. That will not work to setup HTTPS.
ye, i find this ip in dns setting, but i dont delete this ip, (Can't remove)
sorry, my eng so bad :c
i dont now where create this ip, how delete
Yes, you must first disable or stop the URL Forwarding and then you can setup your DNS A records. I'm not sure how you do that but maybe this
ye, i give good result with sertificate, but my domen dont work, not loading in browse
Maybe browser cached old bad info. Refresh browser
Your cert looks good. Use a site like this to test it
ye, (It's all good. We have not detected any issues.)
clean cache, but site dont work, may be you need more info, and help me
I see a default WordPress admin / install page
Our job is usually done once you get a valid cert used by your server.
Beyond that is usually just server and application design.
why i dont use this site in my internet connection. another connection dont have prob, but my internet ip, dont work
Sorry. I am signing off for night.
But, can you explain more in your own language? We can use google translate
да, спасибо большое за помощь, вы действительно очень помогли, спасибо!
через мой интернет (интернет провайдер ethernet) не получается зайти на сайт, но через мобильный интернет получается
I'm able to connect via HTTP - It redirects to HTTPS.
I'm also able to connect via HTTPS now.
I see a new site about philosophy.
да, мы пока не настраивали его, а почему я не могу зайти на него через свой интернет?
There could be different reasons for that.
Are there any geo-location based IP blocking?
