My domain is: grollige.com
2022/06/01 18:39:10.932149 system_key.go:129: cannot determine nfs usage in generateSystemKey: cannot parse /etc/fstab: expected between 3 and 6 fields, found 8
Processing /etc/letsencrypt/renewal/grollige.com.conf
Certificate is due for renewal, auto-renewing...
Failed to renew certificate grollige.com with error: Requesting acme-v02.api.letsencrypt.org/directory: No route to host
/etc/letsencrypt/live/grollige.com/fullchain.pem (failure)
nginx/1.18.0 (Ubuntu)
Ubuntu 20
IONOS
Yes
No
certbot 1.25.0
Machine is healthy (as far as I can tell). This is the first time I've tried to renew my cert. Hopefully, all necessary information is above. Thanks.
