Failed to Renew
Greetings all,
I am hoping someone can point me in the right direction, renewing a certificate. the machine have been up for years without any hiccups and today the certificate expired and I cannot renew. I have neglected this machines and my Ubuntu skills have not been utilized for quite some time - time ti get back in the grind.
Thank you advance for the support and guidance and please let me know what further information can be provided.
  • Ping test are successful to dns name
  • Firewall is inactive
  • Log File Attached
certbot --version
certbot 1.21.0
Web Server Version - apache2 -v
Server version: Apache/2.4.52 (Ubuntu)
Server built: 2026-03-05T18:04:29
Ubuntu Version - lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description: Ubuntu 22.04.3 LTS
Release: 22.04
Codename: jammy
sudo apachectl configtest
Syntax OK
certbot certificates
Found the following certs:
Certificate Name: nextcloud.eclipsephoto.net
Serial Number: 5e5130c96ea847f1e75fd277768d2b40716
Key Type: RSA
Domains: nextcloud.eclipsephoto.net
Expiry Date: 2026-03-24 03:07:58+00:00 (INVALID: EXPIRED)
Certificate Path: /etc/letsencrypt/live/nextcloud.eclipsephoto.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/nextcloud.eclipsephoto.net/privkey.pem
letsencrypt.txt (380.4 KB)
Processing /etc/letsencrypt/renewal/nextcloud.eclipsephoto.net.conf
Certificate is due for renewal, auto-renewing...
Simulating renewal of an existing certificate for nextcloud.eclipsephoto.net
http-01 challenge for nextcloud.eclipsephoto.net
Challenge failed for domain nextcloud.eclipsephoto.net
Domain: nextcloud.eclipsephoto.net
Type: connection
Detail: 207.237.25.23: Fetching http://nextcloud.eclipsephoto.net/.well-known/acme-challenge/Sz5W9bac9NyMi1VkO5_n877-nDCZA_WxVJKMqYaRLXg: Timeout during connect (likely firewall problem)
Failed to renew certificate nextcloud.eclipsephoto.net with error: Some challenges have failed.
All simulated renewals failed. The following certificates could not be renewed:
/etc/letsencrypt/live/nextcloud.eclipsephoto.net/fullchain.pem (failure)
Welcome @ylafont thanks for all the great info. The key part is this:
HTTPS requests using port 443 are reaching your server just fine. They see an expired cert but the connection at least works.
But, HTTP requests using port 80 are failing. Have you recently gotten a new router or some other network related change? Because that is most likely where the problem lies. The --apache option you use with Certbot uses an HTTP Challenge that requires port 80 connections to work.
Focus on any changes since you last got a cert on Dec24 last year
We can reproduce the problem using the Let's Debug test site. It is a good one to use as you make changes trying to correct this before you try to get a cert.
