Failed to renew cert -- possible port confusion
My domain is: icanhome.e2snail.com
My web server is (include version): I have a Synology NAS DS415+ version DSM 7.0.1-42218 Update 2
I am trying t orenew the certificate that is already installed. I have followed the process step by step.
The IPaddress of the NAS is 192.168.1.170. I have place portforwarding for port 443, 8443, and 80 from my external router to the NAS device. See image below. This for both UDP and TCP.
I do the following.
step1: under Security, I edit the shown certificate.
step2: I select to get a new certificate.
step3: I inserted the domain details and selectnext.
After waiting about 4 mins I keep getting the below error and I cannot figure out why. I do have access to the NAS from the internet without hassles.
Don't know if this is even relevant, but these domains are allocated to specific ports, for this domain I use port 5000.
Do you have any advice
Lawrence
This address times out for me on port 80.
Are you sure your port forwarding is working and your ISP is not getting in the way?
Sorry i don't understand. Thsi is not being served on port 80. it is not a web site it is a synology NAS I could open port 80 for teh cert and then close it down again.
Will keep you informed, thanks
I have just checked and the firewall on the Synology NAS is not configured.
I have also checked on the networ setting and HTTPS and HTTP are both set to respond.
I would assume that with the firewall not enabled and the HTTP response set to reply, and I have the ports open on my unifi portforwarding set to allow traffic on port 80 and 443 and 8443, there should be no issue.
Did a little more searching and found the following.
I tailed the /var/log/messages file and saw the following.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.256065] Module [xt_recent] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.280658] Module [xt_iprange] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.297753] Module [xt_limit] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.314332] Module [xt_state] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.342591] Module [xt_multiport] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.382599] Module [xt_LOG] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.408560] Module [nf_conntrack_ipv4] is removed.
2022-02-04T15:50:32+01:00 ICANHOME kernel: [1200745.515483] Module [nf_defrag_ipv4] is removed.
2022-02-04T15:50:32+01:00 ICANHOME syno-letsencrypt[4436]: client_v2.cpp:468 Failed to open port
2022-02-04T15:50:45+01:00 ICANHOME syno-letsencrypt[4436]: client_v2.cpp:808 Failed to do new authorization, may retry with another type. [{"error":101,"file":"client_v2.cpp","msg":"Fetching http://nas.e2snail.com/.well-known/acme-challenge/Dp3R6XaSp9ytNNLUPYCkVgTmMaWi6wc10I4YWU0zLuw: Timeout during connect (likely firewall problem)"}
Then I checked the ports open on my NAS.
AS you can see port 80 is open.
Now I have checked port 80 on the NAS and also port 80 on my unifi firewall. bith are opened.
Now I have no idea.
Lawrence
You should accept port 80 and NAT/PortForward it directly to 5000.
