Hello I have a question on how to correctly configure certbot installed with snap in Ubuntu to automatically renew the cert.
Basically my site is hosted with nginx and the cert needs renewal few days ago and it failed.
So I need to manually renew it by using sudo certbot renew --nginx
(without --nginx flag it will say "timeout during connect (likely firewall problem)", probably because it does not know how to do the ACME challenge).
Then I go into the logs for the certbot renew service:
sudo systemctl status snap.certbot.renew.service
Sep 27 00:54:29 desktop systemd[1]: Starting Service for snap application certbot.renew...
Sep 27 00:57:09 desktop certbot.renew[71602]: Failed to renew certificate with error: Some challenges have failed.
Sep 27 00:57:09 desktop certbot.renew[71602]: All renewals failed. The following certificates could not be renewed:
Sep 27 00:57:09 desktop certbot.renew[71602]: /etc/letsencrypt/live/mysite.com/fullchain.pem (failure)
Sep 27 00:57:09 desktop certbot.renew[71602]: 1 renew failure(s), 0 parse failure(s)
Sep 27 00:57:09 desktop systemd[1]: snap.certbot.renew.service: Main process exited, code=exited, status=1/FAILURE
Sep 27 00:57:09 desktop systemd[1]: snap.certbot.renew.service: Failed with result 'exit-code'.
Sep 27 00:57:09 desktop systemd[1]: Failed to start Service for snap application certbot.renew.
Apparently it has the same problem where the automatic renewal service don't know to use --nginx
to do ACME challenge.
How do I make the automatic renewal work?
Thanks all
NOTE: My server is listening on port 8080 and when the renewal failed I read about the ACME challenge need to open port 80 for it to work. At the point when trying to renew manually I also added --nginx
flag so I am not sure if the '--nginx' or the port opening is the cause. Since my cert is renewed now I can't test what happened if I close port 80 off. So I can only test this 3 months later...
