Operating system: Debian GNU/Linux 8.7 (jessie) (3.16.0-4-amd64)
Web server: Apache/2.4.10 (Debian) (apache2handler)
Hosting provider: Hetzner, VServer
Root shell Login: Yes
Control panel: No
If i try to renew my certs i get only by anzah.cloud a error message but all domains are on the same root and all domains use cloudflare.
So i dont understand why 4 Domains run seccessfully and 2 have a problem.
# certbot renew --dry-run
Processing /etc/letsencrypt/renewal/mysql.anzah.network.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for mysql.anzah.network
Generating key (2048 bits): /etc/letsencrypt/keys/0018_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0018_csr-certbot.pem
Processing /etc/letsencrypt/renewal/anzah.cloud.conf
tls-sni-01 challenge for anzah.cloud
Attempting to renew cert from /etc/letsencrypt/renewal/anzah.cloud.conf produced an unexpected error: Failed authorization procedure. anzah.cloud (tls-sni-01): urn:acme:error:tls :: The server experienced a TLS error during domain verification :: Failed to connect to 104.28.2.182:443 for tls-sni-01 challenge. Skipping.
Processing /etc/letsencrypt/renewal/paste.anzah.network.conf
tls-sni-01 challenge for paste.anzah.network
Generating key (2048 bits): /etc/letsencrypt/keys/0019_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0019_csr-certbot.pem
Processing /etc/letsencrypt/renewal/www.anzah.cloud.conf
tls-sni-01 challenge for www.anzah.cloud
Attempting to renew cert from /etc/letsencrypt/renewal/www.anzah.cloud.conf produced an unexpected error: Failed authorization procedure. www.anzah.cloud (tls-sni-01): urn:acme:error:tls :: The server experienced a TLS error during domain verification :: Failed to connect to 104.28.2.182:443 for tls-sni-01 challenge. Skipping.
Processing /etc/letsencrypt/renewal/bug.anzah.network.conf
tls-sni-01 challenge for bug.anzah.network
Generating key (2048 bits): /etc/letsencrypt/keys/0020_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0020_csr-certbot.pem
Processing /etc/letsencrypt/renewal/tsw.anzah.network.conf
tls-sni-01 challenge for tsw.anzah.network
Generating key (2048 bits): /etc/letsencrypt/keys/0021_key-certbot.pem
Creating CSR: /etc/letsencrypt/csr/0021_csr-certbot.pem
The following certs were successfully renewed:
/etc/letsencrypt/live/mysql.anzah.network/fullchain.pem (success)
/etc/letsencrypt/live/paste.anzah.network/fullchain.pem (success)
/etc/letsencrypt/live/bug.anzah.network/fullchain.pem (success)
/etc/letsencrypt/live/tsw.anzah.network/fullchain.pem (success)
The following certs could not be renewed:
/etc/letsencrypt/live/anzah.cloud/fullchain.pem (failure)
/etc/letsencrypt/live/www.anzah.cloud/fullchain.pem (failure)
2 renew failure(s), 0 parse failure(s)
Domain: anzah.cloud
Type: tls
Detail: Failed to connect to 104.28.2.182:443 for tls-sni-01
challenge
you have an up-to-date TLS configuration that allows the server to
communicate with the Certbot client.
Domain: www.anzah.cloud
Type: tls
challenge
root@Anzah-Cloud ~ #
