Failed to connect to 1.2.3.4:443 for TLS-SNI-01
The apache server proc is dying each time. See the apache log snippet further below.
I’ve tried a few variations including ‘–standalone-supported-challenges http-01’ but ultimately I won’t get anywhere if the apache proc isn’t running. What could be killing it?
certbot renew --dry-run
Processing /etc/letsencrypt/renewal/f.ff.me.conf
Starting new HTTPS connection (1): acme-staging.api.letsencrypt.org
tls-sni-01 challenge for f.ff.me
Job for httpd.service invalid.
Attempting to renew cert from /etc/letsencrypt/renewal/f.ff.me.conf produced an unexpected error: Error while running apachectl graceful.
. Skipping.
**          (The test certificates below have not been saved.)
  /etc/letsencrypt/live/f.ff.me/fullchain.pem (failure)
**          (The test certificates above have not been saved.)
   Domain: f.ff.me
   Type:   connection
   Detail: Failed to connect to 1.2.3.4:443 for TLS-SNI-01
   challenge
[Fri Jan 20 20:10:50.932434 2017] [mpm_prefork:notice] [pid 14096] AH00171: Graceful restart requested, doing restart
AH00112: Warning: DocumentRoot [/var/lib/letsencrypt/tls_sni_01_page/] does not exist
[Fri Jan 20 20:11:00.986644 2017] [auth_digest:notice] [pid 14096] AH01757: generating secret for digest authentication ...
[Fri Jan 20 20:11:00.988249 2017] [ssl:emerg] [pid 14096] (2)No such file or directory: AH02201: Init: Can't open server certificate file /var/lib/letsencrypt/3Nun84ung5Kjx9HzIfVhTlLldqEc5lhv_3OmegY6lHA.crt
[Fri Jan 20 20:11:00.988278 2017] [ssl:emerg] [pid 14096] AH02312: Fatal error initialising mod_ssl, exiting.
Hi @ezekieldas,
Did you redact your IP address and replace it with 1.2.3.4 for this post, or is that actually the IP address that the CA is attempting to validate to?
Hi @schoen. Yes the ipaddr is masked with 1.2.3.4.
I was able to find a semi-acceptable solution to the issue with using the manual ‘webroot’ approach. However this is short term and I expect to encounter trouble again on next renewal.
I believe this has something to do with how the system is hardened. Possibly an selinux issue. I can try to reproduce this coming week. Still looking for ideas regarding why http proc is crashing at the temporary DocumentRoot.
The DocumentRoot warning is expected; that’s probably not what’s causing the problem.
I’d guess it’s this one:
Not sure what would cause that, although with selinux you never know.
