Failed to connect for TLS-SNI-01 challenge: please help
tls-sni-01 challenge for dev.xxxx.com
Enabled Apache ssl module
Waiting for verification…
Failed authorization procedure. dev.xxxxxxcom (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Failed to connect to xx.xx.xx.xx:443 for TLS-SNI-01 challenge
    Domain: dev.xxxxxx.com
    Type: connection
    Detail: Failed to connect to xx.xx.xx.xx:443 for TLS-SNI-01
    challenge
  • No cloudflare
  • 443 port is opened (it can be telned)
  • xx.xx.xx.xx is public and visible, same for dev.xxxxxx.com
  • DNS set correctly
Any clue ?
You odn’t need to obfuscate your domain or IP, we’ll see the domain as soon as the cert is issued due to cert transparaency, and we’ll be able to look up IP from there. But, to answer your question (or at least try to): could you please fill in the support form? Cheeers.
