Failed authorization procedure with Glassfish and Debian
alcora.ru
sudo certbot certonly --webroot -w /var/www/alcora -d alcora.ru -d www.alcora.ru
Failed authorization procedure. alcora.ru (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://alcora.ru/.well-known/acme-challenge/sJMtuscVogPTnYQYUztk-NAO_iwuNp2br9IS-IKTDw4: "<html xmlns=“http:/”, www.alcora.ru (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.alcora.ru/.well-known/acme-challenge/K2IEH-FiqfVcQvfelKC93QlBQ2LGyet3xDfiTYMLQ74: "<html xmlns=“http:/”
Debian 8 jessie
Glassfish 4.1.1
Linode.com
no (glassfish administration console only)
Additional information:
I’ve actually create directory /.well-known/acme-challenge and verified that I have access to it from browser when I type http://alcora.ru/.well-known/acme-challenge/index.html
What can be a cause of the problem described? Thank you for any help!
This also gives a 404 Not Found-error on my browser.
Thank you for your reply!
Actually I've already removed that file from the server. I used standalone version of certbot. And successfully download four files: cert.pem, chain.pem, fullchain.pem and privkey.pem. Then, I used the following code:
But face the same problem. I cannot login into administration console (port 4848). But with the different error:
SSLHandshakeException
At port 8181 ssl works perfectly.
Can you give me a clue of how to solve this problem?
Solved the problem using this link:
https://maximilian-boehm.com/hp2121/Create-a-Java-Keystore-JKS-from-Let-s-Encrypt-Certificates.htm
