Hello again. I’m trying to set ssl cert on debian 10 with nginx via certbot
after selecting the desired domain name and vhost I recieved such error message:
Failed authorization procedure. jouve-corp.fr (http-01): urn:ietf:params:acme:error:unauthorized :: The client lacks sufficient authorization :: Invalid response from http://www.jouve-corp.fr [213.186.33.5]: “<html xml:lang=“fr-FR” lang=“fr-FR”>\n\n<title qtlid=“28806”>F\xe9licitations ! Votre domaine a bien \xe9t\xe9 cr\xe9\xe9 chez OVH !</”
Domain: jouve-corp.fr
Detail: Invalid response from http://www.jouve-corp.fr
lang=“fr-FR”>\n\n<title qtlid=“28806”>Félicitations !
Votre domaine a bien été créé chez OVH !</”To fix these errors, please make sure that your domain name was
Please tell, what should I check and fix?
