Failed authorization procedure.Timeout during connect (likely firewall problem)
Installing Nextcloud on a Raspberry Pi, I am facing issued when trying to create a letsencrypt certificate.
The ip address I added to my DynDNS provider (spdyn.de) is the ip address I found out by typing into a webbrowser “ifconfig.me” from my computer, not the raspberry. But it should be the same because this should be the public ip address of my router right? In my router (FritzBox) I granted access to the local ip address of my pi (192.168.178.35) for port 80 and 443.
I followed this instruction for setting up Nextcloud on a Raspberry Pi: https://canox.net/2016/06/die-eigene-cloud-mit-dem-raspberry-pi-und-nextcloud/
I do not know, why creating the certificates is failing. However, I am new to these topics and can not verify, if I setted up my DynDNS correctly.
wolke4000.spdns.org
I ran this command on the raspberry pi with user pi (not root):
sudo certbot certonly --webroot -w /var/www/html/ -d wolke4000.spdns.org -m raspnextfritz@mailbox.org --agree-tos
Would you be willing to share your email address with the Electronic Frontier
Foundation, a founding partner of the Let’s Encrypt project and the non-profit
organization that develops Certbot? We’d like to send you email about our work
encrypting the web, EFF news, campaigns, and ways to support digital freedom.
(Y)es/(N)o: Y
http-01 challenge for wolke4000.spdns.org
Using the webroot path /var/www/html for all unmatched domains.
Waiting for verification…
Failed authorization procedure. wolke4000.spdns.org (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://wolke4000.spdns.org/.well-known/acme-challenge/TH_dPnmFeEnAtSScmk_G1ovJ-riURPQsGlLOLer7dcc: Timeout during connect (likely firewall problem)
    Domain: wolke4000.spdns.org
    Type: connection
    Detail: Fetching
  • Your account credentials have been saved in your Certbot
  • We were unable to subscribe you the EFF mailing list because your
    e-mail address appears to be invalid. You can try again later by
    visiting https://act.eff.org.
I do not know how the get that information from my raspberry. However, during the setup process I executed this command:
sudo apt install git certbot unzip nginx postgresql curl libcurl4 redis-server php7.3-fpm php7.3-curl php7.3-gd php7.3-intl php7.3-mbstring php7.3-opcache php7.3-xml php7.3-xmlrpc php7.3-zip php7.3-apcu php7.3-common php7.3-intl php-pear php7.3-apcu php7.3-xml php7.3-mbstring php7.3-zip php7.3-pgsql php7.3-intl php-imagick php7.3-json php7.3-bz2 php-smbclient redis-server php-redis
Linux raspberrypi 4.19.97-v7l+ #1294 SMP Thu Jan 30 13:21:14 GMT 2020 armv7l GNU/Linux
spdyn.de
I can log in using PUTTY and ssh, but only with the user “pi”.
No
certbot 0.31.0
Hi @raspnextfritz
your http doesn't answer.
A working port 80 is required if you want to create a certificate via http validation.
Read
and fix your timeout. May be a firewall. May be a missing router forward.
Hey @JuergenAuer, thank you very much for you answer. I followed the instructions you provided. However, it did not solve my issue.
I followed in “Challenge Types - Let’s Encrypt - Free SSL/TLS Certificates” the steps in " HTTP-01 challenge". Therefore I change from password authentification to token authentification in my DynDNS provider spdyn.de. I still get the same error message as posted earlier.
Port 80 is activated on my FritzBox. The raspberry pi 4 does not have a firewall itsself which needs to be deactived?
Your port 80 doesn't answer - see https://check-your-website.server-daten.de/?q=wolke4000.spdns.org
http://wolke4000.spdns.org/ 89.246.122.49 -14 10.036 T
Timeout - The operation has timed out
https://wolke4000.spdns.org/ 89.246.122.49 -14 10.027 T
http://wolke4000.spdns.org/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 89.246.122.49 -14 10.030 T
Visible Content:
Only timeouts, no answer.
