Failed authorization procedure Connection refused
When i execute
certbot certonly --standalone -d cupon2go.com -d www.cupon2go.com
i recive the following message in console:
tls-sni-01 challenge for cupon2go.com
tls-sni-01 challenge for www.cupon2go.com
Waiting for verification…
Failed authorization procedure. www.cupon2go.com (tls-sni-01): urn:acme:error:connection :: The server could not co
nnect to the client to verify the domain :: Connection refused
    Domain: www.cupon2go.com
    Type: connection
    Detail: Connection refused
I verify and i had 2 register A for this domain in DNS one for cupon2go.com and other for www.cupon2go.com
When i trace both domain i have the following same result:
Received authoritative (AA) response:
-> Answer: A-record for cupon2go.com = 35.188.79.253
-> Answer: A-record for www.cupon2go.com = 35.188.79.253
Can you help me, my problem is only for www.cupon2go.com, if i generate de cert only for cupon2go.com is generate succefull.
Thanks.
You’re using --standalone, which by default uses the tls-sni-01 challenge type, which operates over port 443. Are you certain that port 443 is open on your firewall, and forwarded to the server running certbot (if applicable)?
Yes, if i run only with cupon2go.com name, the certificate is generate correctly. I review the ports of my firewall and 443 port is open.
What command did you run to get the single name cert?
Hi, i run
hi i run
(please retype them new or copy from this screen - do not reuse your pre-existing code)
Please try:
certbot certonly --standalone -d www.cupon2go.com
and also:
certbot certonly --standalone -d cupon2go.com -d cupon2go.com
Hi i run the following commmands:
sudo certbot certonly --standalone -d www.cupon2go.com
Failed authorization procedure. www.cupon2go.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Timeout
    Type: connection
    Detail: Timeout
sudo certbot certonly --standalone -d cupon2go.com
Cert not yet due for renewal
You have an existing certificate that has exactly the same domains or certificate name you requested and isn’t clos
e to expiry.
(ref: /etc/letsencrypt/renewal/cupon2go.com.conf)
What would you like to do?
1: Keep the existing certificate for now
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
    /etc/letsencrypt/live/cupon2go.com/fullchain.pem
    /etc/letsencrypt/live/cupon2go.com/privkey.pem
    Your cert will expire on 2018-01-28. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot
    again. To non-interactively renew all of your certificates, run
    "certbot renew"
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
I have never seen this before!
@cpu, could you see what it looks like from the server side (do these names resolve to the same IP address?)? You wouldn’t be able to test the actual TCP connection because @mexicanobermudez is using standalone, so the listener isn’t active all of the time.
Maybe there’s something from the existing settings that’s different when you do the renewal as opposed to getting a fresh certificate. Could you post the contents of the file /etc/letsencrypt/renewal/cupon2go.com.conf?
Sure
The content of /etc/letsencrypt/renewal/cupon2go.com.conf:
renew_before_expiry = 30 days
version = 0.18.1
archive_dir = /etc/letsencrypt/archive/cupon2go.com
cert = /etc/letsencrypt/live/cupon2go.com/cert.pem
privkey = /etc/letsencrypt/live/cupon2go.com/privkey.pem
chain = /etc/letsencrypt/live/cupon2go.com/chain.pem
fullchain = /etc/letsencrypt/live/cupon2go.com/fullchain.pem
[renewalparams]
authenticator = standalone
installer = None
account = 2c69d1d1f5d5246e139933435ddfc3f2
@bmw, can you think of a reason why Certbot would start a different kind of standalone listener with the certbot certonly renewal here vs. with the certbot certonly fresh cert issuance? I can’t think of a plausible reason, but the CA seems to find a TCP listener listening in one case and not in the other, on the same host with names that resolve to the same address.
FYI i add the trace for resolution of each domain
Tracing DNS delegation for “www.cupon2go.com”:
Loading root server list (static data):
-> a.root-servers. net (198.41.0.4)
-> b.root-servers. net (192.228.79.201)
-> c.root-servers. net (192.33.4.12)
-> d.root-servers. net (128.8.10.90)
-> e.root-servers. net (192.203.230.10)
-> f.root-servers. net (192.5.5.241)
-> g.root-servers. net (192.112.36.4)
-> h.root-servers. net (128.63.2.53)
-> i.root-servers. net (192.36.148.17)
-> j.root-servers. net (192.58.128.30)
-> k.root-servers. net (193.0.14.129)
-> l.root-servers. net (199.7.83.42)
-> m.root-servers. net (202.12.27.33)
Sending request to “k.root-servers. net” (193.0.14.129)
Received referral response - DNS servers for “com”:
-> a.gtld-servers. net (192.5.6.30)
-> b.gtld-servers. net (192.33.14.30)
-> c.gtld-servers. net (192.26.92.30)
-> d.gtld-servers. net (192.31.80.30)
-> e.gtld-servers. net (192.12.94.30)
-> f.gtld-servers. net (192.35.51.30)
-> g.gtld-servers. net (192.42.93.30)
-> h.gtld-servers. net (192.54.112.30)
-> i.gtld-servers. net (192.43.172.30)
-> j.gtld-servers. net (192.48.79.30)
-> k.gtld-servers. net (192.52.178.30)
-> l.gtld-servers. net (192.41.162.30)
-> m.gtld-servers. net (192.55.83.30)
Sending request to “l.gtld-servers. net” (192.41.162.30)
Received referral response - DNS servers for “cupon2go.com”:
-> ns-cloud-c1.googledomains. com (216.239.32.108)
-> ns-cloud-c2.googledomains .com (216.239.34.108)
-> ns-cloud-c3.googledomains. com (216.239.36.108)
-> ns-cloud-c4.googledomains .com (216.239.38.108)
Sending request to “ns-cloud-c4.googledomains. com” (216.239.38.108)
-> Answer: A-record for www.cupon2go.com = 35.202.242.4
Tracing DNS delegation for “cupon2go.com”:
Sending request to “f.root-servers. net” (192.5.5.241)
-> g.gtld-servers. net (no IP address)
-> a.gtld-servers. net (no IP address)
-> h.gtld-servers. net (no IP address)
-> i.gtld-servers. net (no IP address)
-> j.gtld-servers. net (no IP address)
-> k.gtld-servers. net (no IP address)
-> m.gtld-servers. net (no IP address)
Sending request to “c.gtld-servers. net” (192.26.92.30)
-> ns-cloud-c2.googledomains. com (216.239.34.108)
-> ns-cloud-c4.googledomains. com (216.239.38.108)
Sending request to “ns-cloud-c1.googledomains. com” (216.239.32.108)
-> Answer: A-record for cupon2go.com = 35.202.242.4
Could you post the log files from /var/log/letsencrypt for both the successful and unsuccessful attempts?
The same IP address was used by the VA. Only the www. timed out.
Thanks for checking, @cpu. So it seems like somehow Certbot must not have started the listener in the same way in these two cases, which is surprising to me.
I cant attach the log because i newer user.
I paste the log in this url
https://www.pastiebin.com/59f77ec00d8df
Hi @mexicanobermudez,
Checking the log, seems certbot can’t start the web server on port 443
2017-10-30 19:27:45,346:DEBUG:acme.standalone:Failed to bind to :443 using IPv4
Are you sure you don’t have another service listening on port 443?
sudo netstat -ptanu | grep ':443'
I can see you have issued 3 certs for coupon2go.com so I suppose whatever is the service listening on your machine on port 443, the first day it was not there so you could issue your cert and now it is working for this domain because Let’s Encrypt is not trying to validate it again (Let’s Encrypt caches the validation for 30 days) but now you can issue a cert for www.coupon2go.com because you have a service listening on port 443… just guessing :wink:
Cheers,
sahsanu
Thanks for advance but i dont have any service listening on port 443
sudo netstat -ptanu | grep ‘:443’
result:
NOTHING
i try with a port i know have a service
sudo netstat -ptanu | grep ‘:8080’
result:
tcp 0 0 0.0.0.0:8080 0.0.0.0:* LISTEN 765/java
Unfortunately this is misleading and I don't think this is the problem here. To automatically handle IPv4 and IPv6 traffic on most systems, Certbot's standalone plugin first attempts to bind to the port for all interfaces using IPv6 and then bind to the port using IPv4. On most Linux systems, binding using IPv4 fails as IPv4 traffic is routed to the IPv6 port, but since this isn't the case on all systems like the BSDs, Certbot tries with both protocols and continues execution if at most one fails.
It's not clear to me what's causing the challenge to fail, but I think what's causing requests for cupon2go.com to succeed is authz reuse. Let's Encrypt has already validated that domain so it's not checking again. I suspect if you run sudo certbot certonly --standalone -d cupon2go.com --dry-run, the command will fail.
