F29 certbot and apache - renew problem
buschbecks.homedns.org
certbot renew --dry-run --apache
see log below
Server version: Apache/2.4.39 (Fedora)
Server built: Apr 2 2019 15:45:55
Fedora F29
myself
no
certbot 0.31.0
renewing my certificate with certbot i run into troubles with apachectl:
[root@xxx letsencrypt]# more letsencrypt.log
2019-04-13 12:56:23,866:DEBUG:certbot.main:certbot version: 0.31.0
2019-04-13 12:56:23,866:DEBUG:certbot.main:Arguments: [’–dry-run’]
2019-04-13 12:56:23,867:DEBUG:certbot.main:Discovered plugins: PluginsRegistry(PluginEntryPoint#apache,PluginEntr yPoint#manual,Pl
uginEntryPoint#null,PluginEntryPoint#standalone,Pl uginEntryPoint#webroot)
2019-04-13 12:56:23,893:DEBUG:certbot.log:Root logging level set at 20
2019-04-13 12:56:23,894:INFO:certbot.log:Saving debug log to /var/log/letsencrypt/letsencrypt.log
2019-04-13 12:56:23,945:DEBUG:certbot.plugins.selection:Reque sted authenticator <certbot.cli._Default object at 0xb5feafec> and i
nstaller <certbot.cli._Default object at 0xb5feafec>
2019-04-13 12:56:23,945:DEBUG:certbot.cli:Var dry_run=True (set by user).
2019-04-13 12:56:23,945:DEBUG:certbot.cli:Var server={‘staging’, ‘dry_run’} (set by user).
2019-04-13 12:56:23,946:DEBUG:certbot.cli:Var server={‘staging’, ‘dry_run’} (set by user).
2019-04-13 12:56:23,946:DEBUG:certbot.cli:Var account={‘server’} (set by user).
2019-04-13 12:56:23,996:INFO:certbot.renewal:Cert not due for renewal, but simulating renewal for dry run
2019-04-13 12:56:23,996:DEBUG:certbot.plugins.selection:Reque sted authenticator apache and installer None
2019-04-13 12:56:24,149:ERROR:certbot.util:Error while running apachectl -v.
apachectl: The “-v” option is not supported.
Thanks for Your help!
Frank
Hi @fbu
looks like a bug in Fedora.
Read
Hi JĂźrgen,
what i really want to do is to automatically renew my certificate without opening port 80 to my system.
Even if i do “dnf downgrade httpd” the server could not connect to the client to verify the domain cause it try to reach the http-address on port 80. --apache ist almost the same as --webroot.
Who can i redirect the challenge to https?
Thanks
Frank
That's not possible if you want to use http-01 validation with Certbot.
You can switch to Certbot + dns-01 validation.
Or you use another client with tls-alpn-01 - validation.
Check
But an open port 80 should never be a problem.
Read
OK, many thanks, problem solved.
I opened Port 80, redirected every traffic to 443 and webroot works fine.
Don’t need working apachectl any more. :sunglasses:
Thanks for Your help! :+1:
