Expand option does not seem to add www subdomain
My domain is: www.mindfulprogress.org
I ran this command: sudo certbot certonly --standalone --expand -d mindfulprogress.org -d www.mindfulprogress.org
It produced this output: You have an existing certificate that has exactly the same domains or certificate name you requested and isn't close to expiry.
My web server is (include version): NGinx 1.24
The operating system my web server runs on is (include version): Ubuntu 22.04
My hosting provider, if applicable, is: GoDaddy
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 2.7.4
When i initially ran certbot I only requested certificates for mindfulprogress.org. When i visit that site in the browser, without www. prepended, the browser says the connection is secure. However, when i add www. then the browser says insecure. Examining the certificate in the browser, it appears there is still only the mindfulprogress.org domain without the www one. After running the command to expand the existing cert on my server to the www also, i restarted my webserver many times but i see no change. What am i doing wrong?
Thanks,
Steven
Please show the output of:
sudo certbot certificates
Nevermind, my browser shows a perfectly fine connection to the www subdomain of your hostname. And I also see the www subdomain in the certificate information: you just need to look at the "Alternative Names" in the details.
You may just need to restart your browser to clear its cache. The cert looks fine as Osiris notes
God, that’s embarrassing. Thank you @Osiris and @MikeMcQ
Good ol’ IT restart solution.
