Hi Guys, I am only a newbie!
I installed the ssl certificate ok but forgot to place the www. before the domain name.
Is there anyway to uninstall and then reinstall with the correct domain name?
Regards
Vince
Regards
Vince
Repeat the same steps you used to get the original certificate. If you used certbot, add the “–expand” flag to tell it to expand the existing certificate.
Also note that the certificate can, and probably should, cover both forms. With Certbot, you could use multiple -d flags to specify all of the names that will apply.
