Good day.
I trying sign site with dehydrated.
Web server nginx.
Site config(piece):
server_name vpstest1.fnxtezt.ru ;
root /var/www/fnxtezt.ru/html;
index index.html index.xml;
try_files $uri $uri/ =404;
location /.well-known/acme-challenge {
alias /var/www/dehydrated;
location ^~ /.well-known {
allow all;
Errors log:
dehydrated -c
INFO: Using main config file /etc/dehydrated/config
Processing vpstest1.fnxtezt.ru
Signing domains...
Generating private key...
Generating signing request...
Requesting new certificate order from CA...
Received 1 authorizations URLs from the CA
Handling authorization for vpstest1.fnxtezt.ru
1 pending challenge(s)
Deploying challenge tokens...
Responding to challenge for vpstest1.fnxtezt.ru authorization...
Cleaning challenge tokens...
Challenge validation has failed
ERROR : Challenge is invalid! (returned: invalid) (result: ["type"] "http-01"
["status"] "invalid"
["error","type"] "urn:ietf:params:acme:error:unauthorized"
["error","detail"] "91.228.155.194: Invalid response from http://vpstest1.fnxtezt.ru/.well-known/acme-challenge/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE: 404"
["error ","status"] 403
["error "] {"type":"urn:ietf:params:acme:error:unauthorized","detail":"91.228.155.194: Invalid response from http://vpstest1.fnxtezt.ru/.well-known/acme-challenge/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE: 404","status":403}
["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/321591379427/FQFBSQ "
["token"] "nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE"
["validationRecord",0,"url"] "http://vpstest1.fnxtezt.ru/.well-known/acme-challenge/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE "
["validationRecord",0,"hostname"] "vpstest1.fnxtezt.ru "
["validationRecord",0,"port"] "80"
["validationRecord",0,"addressesResolved",0] "91.228.155.194"
["validationRecord",0,"addressesResolved"] ["91.228.155.194"]
["validationRecord",0,"addressUsed"] "91.228.155.194"
["validationRecord",0,"resolverAddrs",0] "A:10.1.12.81:27532"
["validationRecord",0,"resolverAddrs",1] "AAAA:10.1.12.83:29977"
["validationRecord",0,"resolverAddrs"] ["A:10.1.12.81:27532","AAAA:10.1.12.83:29977"]
["validationRecord",0] {"url":"http://vpstest1.fnxtezt.ru/.well-known/acme-challenge/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE","hostname":"vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.1.12.81:27532","AAAA:10.1.12.83:29977 "]}
["validationRecord"] [{"url":"http://vpstest1.fnxtezt.ru/.well-known/acme-challenge/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE","hostname":"vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.1.12.81:27532","AAAA:10.1.12.83:29977 "]}]
["validated"] "2024-03-02T12:35:27Z")
Nginx errors log:
2024/03/02 12:40:11 [error] 2141#2141: *13 open() "/var/www/dehydrated/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE","hostname":"vpstest1.fnxtezt.ru ","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.1.12.81:27532","AAAA:10.1.12.83:29977" failed (2: No such file or directory), client: 184.105.99.36, server: vpstest1.fnxtezt.ru , request: "GET /.well-known/acme-challenge/nrE8xo6iAruFoqKPj9LTUoS5E0CPxSFdafdi8jIpAyE%22,%22hostname%22:%22vpstest1.fnxtezt.ru %22,%22port%22:%2280%22,%22addressesResolved%22:%5B%2291.228.155.194%22%5D,%22addressUsed%22:%2291.228.155.194%22,%22resolverAddrs%22:%5B%22A:10.1.12.81:27532%22,%22AAAA:10.1.12.83:29977 HTTP/1.1", host: "vpstest1.fnxtezt.ru "
Also, I disable ipv6 in centos, but no luck.
I am sorry, This log too much. Too many details.
cause of this error are wrong location for .well-known/acme-challenge ? Or other cause.
Ps. look like 443 port opened in firewall, but unsure.
Should I use site location or separate directory for dehydrated?
Separate is best but you should use root
instead of alias
for this situation.
The 404 error means that dehydrated placed the challenge token in the folder you said. But, when Let's Encrypt server tried to find that token your nginx said 404 Not Found.
So, the path in your nginx is not matching the folder you said in dehydrated.
I see you got 3 2 certs yesterday. What have you changed to make this not work? Be careful because you can only get 5 certs per week with the same names and many more will get you blocked for a week. You should use the Let's Encrypt staging system when testing. I don't know how you do that in dehydrated.
Unfortunatelly, this not working.
I replace syntax config. No luck. After I tried replace path for .well-known :
root /var/www/fnxtezt.ru/html/;
This is not working.
ERROR: Challenge is invalid! (returned: invalid) (result: ["type"] "http-01"
["error","detail"] "91.228.155.194: Invalid response from http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/dfZI-I38gYdUIU3qF_ZURWaVKhdwnKLpbie-3z4jTLY: 404"
["error","status"] 403
["error"] {"type":"urn:ietf:params:acme:error:unauthorized","detail":"91.228.155.194: Invalid response from http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/dfZI-I38gYdUIU3qF_ZURWaVKhdwnKLpbie-3z4jTLY: 404","status":403}
["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/321619994287/uVdOuA "
["token"] "dfZI-I38gYdUIU3qF_ZURWaVKhdwnKLpbie-3z4jTLY"
["validationRecord",0,"url"] "http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/dfZI-I38gYdUIU3qF_ZURWaVKhdwnKLpbie-3z4jTLY "
["validationRecord",0,"hostname"] "www.vpstest1.fnxtezt.ru "
["validationRecord",0,"resolverAddrs",0] "A:10.0.12.81:30446"
["validationRecord",0,"resolverAddrs",1] "AAAA:10.0.12.81:30446"
["validationRecord",0,"resolverAddrs"] ["A:10.0.12.81:30446","AAAA:10.0.12.81:30446"]
["validationRecord",0] {"url":"http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/dfZI-I38gYdUIU3qF_ZURWaVKhdwnKLpbie-3z4jTLY","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.0.12.81:30446","AAAA:10.0.12.81:30446 "]}
["validationRecord"] [{"url":"http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/dfZI-I38gYdUIU3qF_ZURWaVKhdwnKLpbie-3z4jTLY","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.0.12.81:30446","AAAA:10.0.12.81:30446 "]}]
["validated"] "2024-03-02T14:34:20Z")
Which folder have you set for wellknown
in dehydrated for the challenge token?
# WELLKNOWN
With `http-01`-type verification (default in this script, there is also support for [dns based verification](dns-verification.md)) Let's Encrypt (or the ACME-protocol in general) is checking if you are in control of a domain by accessing a verification file on an URL similar to `http://example.org/.well-known/acme-challenge/m4g1C-t0k3n`.
It will do that for any (sub-)domain you want to sign a certificate for.
At the moment you'll need to have that location available over normal HTTP on port 80 (redirect to HTTPS will work, but starting point is always HTTP!).
dehydrated has a config variable called `WELLKNOWN`, which corresponds to the directory which should be served under `/.well-known/acme-challenge` on your domain. So in the above example the token would have been saved as `$WELLKNOWN/m4g1C-t0k3n`.
If you only have one docroot on your server you could easily do something like `WELLKNOWN=/var/www/.well-known/acme-challenge`, for anything else look at the example below.
## Example Usage
If you have more than one docroot (or you are using your server as a reverse proxy / load balancer) the simple configuration mentioned above wouldn't work, but with just a few lines of webserver configuration this can be solved.
An example would be to create a directory `/var/www/dehydrated` and set `WELLKNOWN=/var/www/dehydrated` in the scripts config.
You'll need to configure aliases on your Webserver:
### Nginx example config
This file has been truncated. show original
WELLKNOWN="/var/www/fnxtezt.ru/html/.well-known/acme-challenge/"
I don't have dehydrated to test but I think this has to match your nginx
WELLKNOWN="/var/www/dehydrated"
and then in your nginx:
root /var/www/dehydrated;
replaced, but still show error.
Responding to challenge for www.vpstest1.fnxtezt.ru authorization...
["error","detail"] "91.228.155.194: Invalid response from http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/syJOKQS00WTFFnbxcSG0rPVBbWVRd6wAhtTlNBEr_78: 404"
["error"] {"type":"urn:ietf:params:acme:error:unauthorized","detail":"91.228.155.194: Invalid response from http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/syJOKQS00WTFFnbxcSG0rPVBbWVRd6wAhtTlNBEr_78: 404","status":403}
["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/321669285137/alrdWA "
["token"] "syJOKQS00WTFFnbxcSG0rPVBbWVRd6wAhtTlNBEr_78"
["validationRecord",0,"url"] "http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/syJOKQS00WTFFnbxcSG0rPVBbWVRd6wAhtTlNBEr_78 "
["validationRecord",0,"resolverAddrs",0] "A:10.1.12.87:22025"
["validationRecord",0,"resolverAddrs",1] "AAAA:10.1.12.82:20692"
["validationRecord",0,"resolverAddrs"] ["A:10.1.12.87:22025","AAAA:10.1.12.82:20692"]
["validationRecord",0] {"url":"http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/syJOKQS00WTFFnbxcSG0rPVBbWVRd6wAhtTlNBEr_78","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.1.12.87:22025","AAAA:10.1.12.82:20692 "]}
["validationRecord"] [{"url":"http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/syJOKQS00WTFFnbxcSG0rPVBbWVRd6wAhtTlNBEr_78","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.1.12.87:22025","AAAA:10.1.12.82:20692 "]}]
["validated"] "2024-03-02T17:44:15Z")
That is a different domain name than earlier. This is the www
subdomain of your earlier requests. Have you updated your nginx server block to include this name?
Good day. I tried remove www subdomain from dehydrated config and nginx:
dehydrated -c
Checking domain name(s) of existing cert... unchanged.
Checking expire date of existing cert...
Valid till May 31 13:34:10 2024 GMT (Longer than 30 days). Skipping renew!
Running automatic cleanup
I tried add www to both, and in this case, dehydrated show old error:
["error","detail"] "91.228.155.194: Invalid response from http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU: 404"
["error"] {"type":"urn:ietf:params:acme:error:unauthorized","detail":"91.228.155.194: Invalid response from http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU: 404","status":403}
["url"] "https://acme-v02.api.letsencrypt.org/acme/chall-v3/322260793107/Qsdo-w "
["token"] "yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU"
["validationRecord",0,"url"] "http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU "
["validationRecord",0,"resolverAddrs",0] "A:10.0.12.85:25640"
["validationRecord",0,"resolverAddrs",1] "AAAA:10.0.12.86:22132"
["validationRecord",0,"resolverAddrs"] ["A:10.0.12.85:25640","AAAA:10.0.12.86:22132"]
["validationRecord",0] {"url":"[http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.0.12.85:25640","AAAA:10.0.12.86:22132 ](http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.0.12.85:25640","AAAA:10.0.12.86:22132 )"]}
["validationRecord"] [{"url":"[http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.0.12.85:25640","AAAA:10.0.12.86:22132 ](http://www.vpstest1.fnxtezt.ru/.well-known/acme-challenge/yRtgB92fDWeceFYuigJCIQ7D-vpJWJKZL98iQSxnBNU","hostname":"www.vpstest1.fnxtezt.ru","port":"80","addressesResolved":["91.228.155.194"],"addressUsed":"91.228.155.194","resolverAddrs":["A:10.0.12.85:25640","AAAA:10.0.12.86:22132 )"]}]
["validated"] "2024-03-04T07:13:17Z")
system
Closed
April 3, 2024, 7:17am
14
