Error with certboot installation
My domain is: giocupo.homepc.it
I ran this command:sudo /opt/certbot/bin/pip install certbot certbot-apache
It produced this output:Collecting python-augeas (from certbot-apache)
Using cached python-augeas-1.2.0.tar.gz (99 kB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Installing backend dependencies ... error
error: subprocess-exited-with-error
× installing backend dependencies for python-augeas did not run successfully.
│ exit code: 1
╰─> [74 lines of output]
Collecting cffi>=1.0.0
Using cached cffi-2.0.0.tar.gz (523 kB)
Installing build dependencies: started
Installing build dependencies: finished with status 'done'
Getting requirements to build wheel: started
Getting requirements to build wheel: finished with status 'done'
Preparing metadata (pyproject.toml): started
Preparing metadata (pyproject.toml): finished with status 'done'
My web server is (include version):Server version: Apache/2.4.65 (Debian)
The operating system my web server runs on is (include version):DEBIAN_VERSION_FULL=13.1
My hosting provider, if applicable, is:vodafone
Did it mention these 74 lines or did you copy/paste this verbatim?
I got more significant error blocks
I don't know what that means and it doesn't seem to answer my question.
@giocupo have you consider using the preferred installation method of Certbot for linix which is snap?
Please see Certbot Instructions
