Error while usinf certbot-auto
retex.global
sudo ./certbot-auto certonly --csr request.csr --webroot -d retex.global -w /data/www --debug
Error: couldn’t get currently installed version for /opt/eff.org/certbot/venv/bin/letsencrypt:
File “/opt/eff.org/certbot/venv/bin/letsencrypt”, line 7, in <module>
from certbot.main import main
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/certbot/main.py”, line 10, in <module>
import josepy as jose
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/josepy/init.py”, line 44, in <module>
from josepy.interfaces import JSONDeSerializable
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/josepy/interfaces.py”, line 8, in <module>
from josepy import errors, util
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/josepy/util.py”, line 4, in <module>
import OpenSSL
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/OpenSSL/init.py”, line 8, in <module>
from OpenSSL import crypto, SSL
File “/opt/eff.org/certbot/venv/local/lib/python2.7/dist-packages/OpenSSL/crypto.py”, line 12, in <module>
from cryptography import x509
ImportError: No module named cryptography
Tomcat
Amazon Linux AMI 2017.09
AWS
no
can’t check due to error
Certbot’s support for Amazon Linux 1 and 2 is “experimental”. Unfortunately you can run into issues like this.
You can try some of the workarounds listed on https://github.com/certbot/certbot/issues/2544, or consider using a different ACME client like acme.sh, lego or others from https://letsencrypt.org/docs/client-options/ .
