Error while running nginx -c /etc/nginx/nginx.conf -t
https://athena.ottawakaraoke.com
sudo certbot --nginx
Error while running nginx -c /etc/nginx/nginx.conf -t.
nginx: [emerg] unknown directive "s" in /etc/nginx/conf.d/wordpress_http.conf:2
nginx: configuration file /etc/nginx/nginx.conf test failed
The nginx plugin is not working; there may be problems with your existing configuration.
The error was: MisconfigurationError('Error while running nginx -c /etc/nginx/nginx.conf -t.\n\nnginx: [emerg] unknown directive "s" in /etc/nginx/conf.d/wordpress_http.conf:2\nnginx: configuration file /etc/nginx/nginx.conf test failed\n')
nginx version: nginx/1.18.0
ubuntu 16
me.com
The version of my client is (e.g. output of `certbot --version` or `certbot-auto --version` if you're using Certbot):
certbot-auto: command not found
Looks like you have an error in your nginx configuration:
Open up that file, look at line 2.
thanks
that was the problem.
