Error while running apachectl graceful
Estou com problemas na instalçao, O erro acontece quando faço a solicitação para criar o certificado.
Job for httpd.service invalid.
Unable to restart apache using [‘apachectl’, ‘graceful’]
Error while running apachectl restart.
Job for httpd.service failed because the control process exited with error code. See "systemctl status
Encountered exception during recovery:
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/error_handler.py”, line 108, in _
self.funcs-1
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot/auth_handler.py”, line 310, in _c
self.auth.cleanup(achalls)
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 231
self.restart()
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 217
self._reload()
File “/opt/eff.org/certbot/venv/lib/python2.7/site-packages/certbot_apache/configurator.py”, line 220
raise errors.MisconfigurationError(error)
MisconfigurationError: Error while running apachectl restart.
Unable to find a virtual host listening on port 80 which is currently needed for Certbot to prove to thport 80.
That means your apache configuration is not correct… (or not running)
Can you please check it by running apachectl configtest
Thank you
Você acha que já tem uma instalação válida do Apache nesse servidor?
Pode preenchar o formulário abaixo para dar mais contexto ao seu problema?
