Error when installing let's encrypt certificate using certbot and apache
aqartop.com
sudo certbot --apache
1: aqartop.com
2: www.aqartop.com
blank to select all options shown (Enter 'c' to cancel): 1 2
Requesting a certificate for aqartop.com and www.aqartop.com
Domain: aqartop.com
Detail: 2a02:4780:b:966:0:24a7:75f:1: Invalid response from http://aqartop.com/.well-known/acme-challenge/dE8OH_XYa_gqmhzJPI-joGUKkIm4ZHWD0JKsATn66_U: 404
Domain: www.aqartop.com
Detail: 2a02:4780:b:966:0:24a7:75f:1: Invalid response from http://www.aqartop.com/.well-known/acme-challenge/8ltIXsanljUxf2dRZinJGidkezFkigvgkqA7e-q-y98: 404
apache2
ubunto 20.04
hostinger
no
certbot 1.21.0
Your domain's IPv4 (A) and IPv6 (AAAA) DNS records are mixed up.
Your IPv6 records point to a Litespeed server.
Your IPv4 records point to an Apache server.
Remove whichever ones are not pointing to the right place.
OR
If you can, update them so they both [IPv4&IPv6] point to the same/correct server.
