Error using DDNS by noip
I’m trying to get my own private cloud, working fine with access on port 80. However I need SSL authentication but any tutorial I found online didn’t work.
Please help…
My domain name (DDNS): asds.noip.me
I set up a VPS with apache on ubuntu 16.04, nextcloud as cloud server.
Port 80 and 443 open on my router firewall.
I tried several commands including:
1)sudo letsencrypt --apache --agree-tos --email struzzoang@gmail.com -d asds.noip.me
2)sudo certbot --apache -d asds.noip.me
3)sudo apt-get install software-properties-common
sudo add-apt-repository ppa:certbot/certbot
sudo apt-get update
sudo apt-get install python-certbot-apache sudo certbot --apache
What I get is always: "Obtaining a new certificate
tls-sni-01 challenge for asds.noip.me
Enabled Apache ssl module
Waiting for verification…
Failed authorization procedure. asds.noip.me (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: Error getting validation data
    Domain: asds.noip.me
    Type: connection
    Detail: Error getting validation data
The TLS-sni-01 challenge requires port 443.
Ensure your firewall is allowing port 80 and 443 inbound.
And place a test.txt file (with minimal content) in the challenge folder for testing:
asds.noip.me/.well-known/acme-challenge/test.txt
That won't affect or predict the success of --apache because --apache only uses TLS-SNI-01, not HTTP-01 challenges.
True, but it could verify the path to the file is correct (at least via HTTP)
This is still a less relevant test because there is no file, nor /.well-known directory, nor use of a webroot, nor even a completed HTTP request, in TLS-SNI-01. It only creates a self-signed certificate and does not perform a full web request.
I have much to learn, sensei
Many thanks for your reply!
I checked using https://www.yougetsignal.com/tools/open-ports/: ports 443
and 80 are open
I couldn’t find a “acme-challenge” folder on my root partition or /var/www
folder. So I made one new folder (asds.noip.me/.well-known/acme-challenge/)
and put a simple test.txt on it; then chowned using www-data:www-data. I
tried to point it from outside: "The requested URL
/.well-known/acme-challenge/test.txt was not found on this server."
http://asds.noip.me/.well-known/acme-challenge/test.txt
Sorry, I’m an absolute beginner, I may have misanderstood your suggestion!
We need this to share mediacal research stuff (mainly using nextcloud) and
set up a stata software server - but we are stuck with SSL authentication.
Hi @angelodl,
The thing I was discussing above is that the acme-challenge directory is only relevant if you use --webroot, not if you use --apache. The --webroot method is less automated than the --apache method; for example, it doesn’t install your certificate for you.
The experiment you tried shows that --webroot won’t work either (without figuring out and fixing whatever went wrong), but it doesn’t explain the error that you saw with --apache. I think that error is most likely explained by a firewall (either a network-based firewall or a host-based firewall) dropping the inbound connections to port 443.
Weird, this is beyond my possibilities, actually I’m a newbie.
I can ssh using port 443 from outside, and my lamp-stack is “standard”.
I tried to stop my router firewall, no luck. I’m using the main ISP in
Italy (Tim), so that shouldn’t be an issue.
I may try to reinstall the system, but this would be a panic!
Thank you
A
That's the issue. Port 443 is OpenSSH. Port 443 needs to be Apache.
You need to move OpenSSH to a different port, or use a multiplexing program like sslh so that OpenSSH and Apache can share the port. (Apache and Certbot would have to be configured carefully, though.)
