TLS-SNI-01 challenge failed due to not able to listen on port 443
It produced this output: failed TLS-SNI-01 challenge
My operating system is (include version):Ubuntu 16.04
My web server is (include version):Apache 2.4
My hosting provider, if applicable, is:home server
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
You haven’t said what command you ran ( so I’ve no idea what client even you are running ).
is your domain accessible on port 443 from the general internet ? (I can’t check, since you didn’t provide a domain name either )
Sorry for the miss…
I’m running a nextcloud server listening on port 8443. I use a dynamic DNS from noip.com. Since I have DHCP setup, my ISP provider blocks me from using port 80 & 443. I use certbot client.
https://dmmloft.ddns.net:8443/nextcloud
Thanks again for your support.
Let’s Encrypt requires ports 80/443 for it’s challenge - so you won’t be able to use certbot.
There is another way which allows you do obtain a certificate by adding the token into your DNS records as proof of ownership / control. The Bash and GO alternative clients support this, currently certbot doesn’t though.
Thank you very much for your great support. I appreciate.
