Any more else need to check please?
It looks like both the protocol and ciphers were changed in:
/etc/nginx/nginx.conf
Before:
/etc/nginx/nginx.conf: ssl_protocols TLSv1.2 TLSv1.3;
/etc/nginx/nginx.conf: ssl_ciphers ‘TLS13-CHACHA20-POLY1305-SHA256:TLS13-AES-256-GCM-SHA384:TLS13-AES-128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256’;
Now:
/etc/nginx/nginx.conf: ssl_protocols TLSv1 TLSv1.1 TLSv1.2 TLSv1.3;
/etc/nginx/nginx.conf: ssl_ciphers ‘TLS13+AESGCM+AES128:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS’;
For now, I found there will still issue with Win7(we can ignore windows xp)
Any suggestions?
Great way of comparing and analysis!
At the page Redirecting to ssl-config.mozilla.org...
There are suggestion for configuration:
listen 80 default_server;
# Redirect all HTTP requests to HTTPS with a 301 Moved Permanently response.
listen 443 ssl http2;
listen [::]:443 ssl http2;
# certs sent to the client in SERVER HELLO are concatenated in ssl_certificate
ssl_certificate /path/to/signed_cert_plus_intermediates;
ssl_certificate_key /path/to/private_key;
ssl_session_timeout 1d;
ssl_session_cache shared:SSL:50m;
ssl_session_tickets off;
# modern configuration. tweak to your needs.
ssl_protocols TLSv1.2;
ssl_ciphers 'ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256';
ssl_prefer_server_ciphers on;
# HSTS (ngx_http_headers_module is required) (15768000 seconds = 6 months)
add_header Strict-Transport-Security max-age=15768000;
# OCSP Stapling ---
# fetch OCSP records from URL in ssl_certificate and cache them
ssl_stapling on;
ssl_stapling_verify on;
## verify chain of trust of OCSP response using Root CA and Intermediate certs
ssl_trusted_certificate /path/to/root_CA_cert_plus_intermediates;
resolver <IP DNS resolver>;
The screenshot shows problems with TLSv1.3 with Chrome 69 and Firefox 62.
Both of those do NOT support the RFC version of TLS 1.3.
This from https://blog.mozilla.org/security/2018/08/13/tls-1-3-published-in-firefox-today/
“We expect to ship the final version in Firefox 63”
Chrome 70 already support it fine.
I just checked the version of Chrome and Firefox.
If so, there is no need to worry about the warning in that screenshot, right?
If you need check more, just feel free to let me know.
I am glad to show more to you.
I would try it again changing one thing at a time.
First test (ciphers):
use:
Check results at SSL Labs and from your test browsers.
If test #1 fails then revert change and restart nginx.
Second test (protocols):
use:
If test #2 fails then revert change and restart nginx.
Third test (TLS 1.3):
Add TLS13
to start of ssl_ciphers:
Like:
ssl_ciphers 'TLS13:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256'
Once all tests have been done, post their results here.
Sorry, my Mac lost internet connection, and I am using iPhone to reply to you.
Once internet recovered, we can test together.
After updated SSl, there is a issue on our site, and here is a detailed information:
For now, we did not add TLS3 in configruation, it would be great if I can have your suggestion.
thanks.
Which tests failed?
Which tests passed?
Did you revert the changes?
