Error: SSL certificate problem: unable to get local issuer certificate
Good day, I’m setting up a speedtest server for ookla, when I do a test on the ookla page, it gives me the following error
could you help me.
Thanks,
My domain is
speedtest.redeshibridas.com.gt
My web server
Is apache2 ubuntu 16.04
My hosting
Redes Hibridas S.A.
Version Cetbot
certbot 0.32.0
Hi @Edson
I don't find a problem (checked with https://check-your-website.server-daten.de/?q=speedtest.redeshibridas.com.gt ):
Your Letsencrypt - certificate is new
CN=speedtest.redeshibridas.com.gt
	11.03.2019
	10.06.2019
expires in 89 days	speedtest.redeshibridas.com.gt - 1 entry
and your https version is ok.
• http://speedtest.redeshibridas.com.gt/
138.94.253.6 200 0.373 H
• https://speedtest.redeshibridas.com.gt/
138.94.253.6 200 6.970 B
• http://speedtest.redeshibridas.com.gt/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
138.94.253.6 404 0.353 A
Same with my browser - there is a standard Apache2 Ubuntu page.
Checked with SSLLabs, there is a Grade A, no incomplete chain:
https://www.ssllabs.com/ssltest/analyze.html?d=speedtest.redeshibridas.com.gt&hideResults=on
Do you have a screenshot?
Thanks,
attached image of the error that I get when I test my server on ookla.com
When consulting the ookla support they indicate the following, but I do not understand, since my certificate is fine.
The certificate is not signed by a trusted authority (checking against Mozilla’s root store). If you bought the certificate from a trusted authority, you probably just need to install one or more Intermediate certificates. Contact your certificate provider for assistance doing this for your server platform.
@JuergenAuer
help please
I have no idea why there is an error message.
Ok, it’s port 8080, not 443.
But checking port 8080 ( https://check-your-website.server-daten.de/?q=speedtest.redeshibridas.com.gt%3A8080 ) there is the same picture: The valid Letsencrypt certificate with the correct intermediate certificate.
Ok, played with OpenSSL: Your port 443 sends the intermediate certificate:
Certificate chain
 0 s:CN = speedtest.redeshibridas.com.gt
   i:C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
 1 s:C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3
   i:O = Digital Signature Trust Co., CN = DST Root CA X3
your port 8080 not:
Certificate chain
So check your port 443 config and copy the two or three lines with the certificate files to your port 8080 - configuration.
@JuergenAuer thanks for information.
I comment, when entering by https to the domain by port 8080 gives it to me safely, I do not understand what it means to place the info of 3 lines from port 443 to port 8080
I also do not know what the local failure error means
I attached the image securely
ooka
Your port 443 / standard https has the correct configuration.
Your special port 8080 / not standard has the wrong configuration.
So find your vHost / port 443 and compare that with the vHost of your port 8080.
That was a good idea.
Now I’ve found a solution to check the “real certificate chain” of a connection. In combination with the port specific check:
speedtest … has now (in the connections) a new row:
|0|s:CN = speedtest.redeshibridas.com.gt|
My own domain has two rows:
|0|s:CN = *.server-daten.de|
|1|s:C = US, O = Let's Encrypt, CN = Let's Encrypt Authority X3|
So it’s visible that the certificate chain is incomplete. And that works with non standard ports. Must add a new warning message :wink:
@JuergenAuer
I already added everything equal to the vhost 8080 and still I get the same error when running the test in digicert.
I attach errors and settings.
Captura
@JuergenAuer
I do not know what else I could do to solve this error
Could we see the Apache configuration? Is it possible that you used cert.pem instead of fullchain.pem somewhere?
Then share your vHost - port 443 - configuration. These are two or three lines you have to copy:
    SSLCertificateFile /usr/local/ssl/crt/public.crt
    SSLCertificateKeyFile /usr/local/ssl/private/private.key
    SSLCertificateChainFile /usr/local/ssl/crt/intermediate.crt
Then restart your Apache and recheck your port 8080. Your incomplete chain is now visible:
Chain - incomplete 0 s:CN = speedtest.redeshibridas.com.gt
@JuergenAuer @schoen
thanks for the info
I attached the images of my configuration in the Vhost 442 and Vhost 8080
tell me if it is properly configured
There are duplicated lines, remove these (ServerName, Include, SSLCertificateFile / keyfile).
And your 8080 doesn’t have a ServerName, perhaps it isn’t used.
I attach images with the updated configuration
