Hey, I’m trying to renew a certificate that I installed on my HAProxy load balancer. I installed it no problem, issued a few forced renewals before going live and it worked, I issued multiple certificates initially no problem. My automatic renewal cron (runs script below) has been failing and I didn’t realise until just now
I had originally installed certbot using apt-get, but read that 0.22.2 had a renewal issue with tls. Installed certbot-auto which installed 0.25.1.
Nothing has changed in my HAProxy config since the initial renewal.
Here’s the renewal config:
$ cat /etc/letsencrypt/renewal/onlinedegrees.und.edu.conf
version = 0.22.2
archive_dir = /etc/letsencrypt/archive/onlinedegrees.und.edu
cert = /etc/letsencrypt/live/onlinedegrees.und.edu/cert.pem
privkey = /etc/letsencrypt/live/onlinedegrees.und.edu/privkey.pem
chain = /etc/letsencrypt/live/onlinedegrees.und.edu/chain.pem
fullchain = /etc/letsencrypt/live/onlinedegrees.und.edu/fullchain.pem
[renewalparams]
installer = None
http01_port = 8888
account = <snip>
authenticator = standalone
tls_sni_01_port = 8888
#!/usr/bin/env bash
# Renew the certificate
certbot-auto renew --force-renewal --tls-sni-01-port=8888
# Concatenate new cert files, with less output (avoiding the use tee and its output to stdout)
bash -c "cat /etc/letsencrypt/live/onlinedegrees.und.edu/fullchain.pem /etc/letsencrypt/live/onlinedegrees.und.edu/privkey.pem > /etc/ssl/onlinedegrees.und.edu/onlinedegrees.und.edu.pem"
# Reload HAProxy
#service hapee-1.7-lb reload
$ ./update-certs.sh
Processing /etc/letsencrypt/renewal/onlinedegrees.und.edu.conf
tls-sni-01 challenge for onlinedegrees.und.edu
Attempting to renew cert (onlinedegrees.und.edu) from /etc/letsencrypt/renewal/onlinedegrees.und.edu.conf produced an unexpected error: Failed authorization procedure. onlinedegrees.und.edu (tls-sni-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: Incorrect validation certificate for tls-sni-01 challenge. Requested 24055e95bf9e64eb66e74668d5323fd2.363bc3d71dbb723d983d0eaae84c71bb.acme.invalid from 34.231.55.226:443. Received 2 certificate(s), first certificate had names "onlinedegrees.und.edu". Skipping.
/etc/letsencrypt/live/onlinedegrees.und.edu/fullchain.pem (failure)
Domain: onlinedegrees.und.edu
Detail: Incorrect validation certificate for tls-sni-01 challenge.
Requested
HaProxy / hapee-1.7-lb.service - HAPEE Load Balancer
Ubuntu 16.04.3 LTS
EC2
Yes
No
