My domain is: radioalgerie.dz
**I ran this command: **
root#ychaouche-PC 13:48:36 ~/DOWNLOADS/TOOLS # ./certbot-auto certonly -d *.radioalgerie.dz -m it_web@algerian-radio.dz
./certbot-auto has insecure permissions!
To learn how to fix them, visit Certbot-auto deployment best practices
/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/cryptography/hazmat/primitives/constant_time.py:26: CryptographyDeprecationWarning: Support for your Python version is deprecated. The next version of cryptography will remove support. Please upgrade to a release (2.7.7+) that supports hmac.compare_digest as soon as possible.
utils.PersistentlyDeprecated2018,
1: Apache Web Server plugin (apache)
2: Spin up a temporary webserver (standalone)
3: Place files in webroot directory (webroot)
Select the appropriate number [1-3] then [enter] (press ‘c’ to cancel): 3
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
root#ychaouche-PC 13:49:49 ~/DOWNLOADS/TOOLS #
My web server is:
nginx 1.10.3
The operating system my web server runs on is :
Linux (unknown)
self-hosted
I can login to a root shell on my machine : yes
I’m using a control panel to manage my site : no
The version of my client is: 1.3.0
