Error in installation
I was using plesk plugin for installation. But from yesterday onwards i am getting error. Anyone is experiencing any issues ?
can you be a little more specific … what exactly is the error that you are getting ?
When i hit install for a new domain and it takes bit long and gets a message
“This operation is taking too long. Check the results in a few minutes.”
I’m not getting any errors.
Is this new domain fully reachable from the general internet ? can you provide the domain name ?
http://www.iaccesscontrol.com/ This is the domain
Thanks - the domain looks OK ( a self signed SSL cert, but that should be OK ).
Any more detailed information in the logs ?
How we can get he log if we install it from the plugin in parallel plesk ?
Is it possible to delete the certificate issues for a domain through parallel plesk ?
Looking forward for a kind reply
In short, yes, you can delete the certificate issued for a domain through parallel plesk.
can I ask what specifically you want to delete and why ? ( an old expired certificate ? You no longer with to use https ? … some other reason )
i have installed a ssl certificate as i updated last week, but it is not working. So thought of deleting and installing fresh.
If yes do you have any documentation how we can remove it from plesk ?
Is there any limitation in no:of domains in a server supported by the lets encrypt ?
The certificate you are currently using on your site is a "parallels plesk" certificate, so the reason things are not working is because the system has not been configured to use the LetsEncrypt certificate. I don't think deleting the "parallels plesk" certificate will help you at all.
No. There is a limit of 100 for domains on a single certificate, but no limit for domains on a server.
i have installed a ssl with letsencrypt plugin with my domain iaccesscontrol.com and it is showing renew button now instead of install.
I am not sure where i have to set the configuration in plesk panel. Sorry for asking again, do you have any documentaion for deleting the certifiate added once and installing it again ?
It depends exactly what version of plesk. If you have ssh access and version 12 - then the commands are shown at http://download1.parallels.com/Plesk/PP12/12.0/Doc/es-ES/online/plesk-unix-cli/index.htm?fileName=39009.htm
Versopm 12.5 i am having, let me check around the link.
Do we have any configuration setting of letsencrypt ?
I’m not sure exactly what you are asking. There are many configuration settings for letsencrypt - see the certbot documentation
here is the error i am getting in log
http://pastebin.com/LSnJCawG
Anyone if experience similar issues, let me know
DEBUG:requests.packages.urllib3.connectionpool:“POST /enterprise/control/agent.php HTTP/1.1” 504 176
Any error in the above statement, still getting it…
