Error al renovar certificado many certificates already issued for exact set of domains
I'm trying to renew the certificate after a long time, but it returns the error: many certificates already issued for exact set of domains.
Thanks for your help.
My domain is: osm.gualeguaychu.gov.ar
I ran this command: sudo certbot certonly --webroot
It produced this output: There were too many requests of a given type :: Error creating new order :: too many certificates already issued for exact set of domains
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): 1.13.0
Hi @fpirovani
please explain: Why are you running that command daily? https://check-your-website.server-daten.de/?q=osm.gualeguaychu.gov.ar#ct-logs
R3 2021-03-06 2021-06-04 osm.gualeguaychu.gov.ar
1 entries duplicate nr. 5 next Letsencrypt certificate: 2021-03-10 14:02:21
ZeroSSL RSA Domain Secure Site CA 2021-03-05 2021-06-04 osm.gualeguaychu.gov.ar
1 entries
R3 2021-03-05 2021-06-03 osm.gualeguaychu.gov.ar
1 entries duplicate nr. 4
1 entries duplicate nr. 3
R3 2021-03-04 2021-06-02 osm.gualeguaychu.gov.ar
1 entries duplicate nr. 2
R3 2021-03-03 2021-06-01 osm.gualeguaychu.gov.ar
1 entries duplicate nr. 1
R3 2021-02-26 2021-05-27 osm.gualeguaychu.gov.ar
1 entries
1 entries
R3 2021-02-25 2021-05-26 osm.gualeguaychu.gov.ar
1 entries
1 entries
R3 2021-02-24 2021-05-25 osm.gualeguaychu.gov.ar
1 entries
And why do you create new certificates if you have a lot of active certificates? That's a waste of resources.
Use one of these certificates you have 60 - 85 days, then create one new certificate.
Hello. thanks for answering.
I don't run the command daily.
I did it today because the certificate I am using expires on March 9th.
Somehow it's running automatically, sorry, I didn't know that was happening.
Could certbot be doing it automatically?
How can I disable it?
Thanks a lot.
I use google translator
That's the standard configuration.
Did you restart your webserver?
certonly doesn't install the certificate and doesn't restart.
what I do is renew the certificate manually when it is about to expire. Until now I have not had this problem, I do not understand what happened.
How do I prevent certbot from running the command daily?
I apologize, I am new and I am learning.
Sorry and thank you very much for your help.
Hola @fpirovani,
Si te sientes más cómodo podemos hablar en español.
La razón por la cual el certificado se está renovando una y otra vez de forma automática es porque certbot cree que el certificado está caducado o próximo a caducar, ¿has modificado algún fichero o permiso en el directorio /etc/letsencrypt/?
Por favor, muéstranos la salida de este comando:
certbot certificates
La otra cosa que me gustaría saber es la razón por la cual tienes que lanzar certbot de forma manual para obtener tu certificado, lo ideal es que puedas automatizarlo para no depender de una acción manual.
Un saludo,
sahsanu
Buen día, gracias por responder, perdón por la demora.
Todavía no me puse a estudiar como automatizar el proceso de renovación, solo cree el certificado y lo copie manualmente en mi servidor.
No he cambiado ningún permiso en esa carpeta, así como lo instale, quedo.
Lo que si hice al ver que no podía renovarlo es borrar el certificado viejo.
No sabía que intentaba automáticamente el certificado, sin haber configurado nada.
¿Certbot ya dejo de intentar renovar el certificado?
¿Cuánto tiempo debo esperar para poder renovarlo?
Muchas gracias por tu ayuda.
La salida del comando es:
Found the following certs:
Certificate Name: monitoreogchu.ddns.net
Serial Number: 30e06b609638733de7e20b89d652ec0ab41
Key Type: RSA
Domains: monitoreogchu.ddns.net
Expiry Date: 2021-03-22 21:34:33+00:00 (VALID: 14 days)
Certificate Path: /etc/letsencrypt/live/monitoreogchu.ddns.net/fullchain.pem
Private Key Path: /etc/letsencrypt/live/monitoreogchu.ddns.net/privkey.pem
Si lo borraste de forma manual entonces ese puede ser el problema, es posible que hayas dejado el fichero de renovación en /etc/letsencrypt/renewal/osm.gualeguaychu.gov.ar.conf pero antes de hacer nada, muestra la salida de este comando:
ls -lR /etc/letsencrypt/
Cuando veamos la salida del comando anterior podremos verlo.
La próxima vez que podrías obtener un certificado para tu dominio seré el miércoles 10 de marzo de 2021 a las 16:02:00 UTC.
De todas formas, veo que has obtenido un certificado de otra CA (ZeroSSL) que ya estás usando en tu sitio.
El certificado lo borre luego de no poder renovarlo.
Así es, provisoriamente use ZeroSSL para obtener el certificado, pero ellos dan solo 3 certificados gratuitos, tengo que solucionar el problema antes que ese certificado caduque.
La salida del comando con y sin sudo son estas:
SI SUDO ***************************************************************************************************************
/etc/letsencrypt/:
total 68
drwx------ 3 root root  4096 sep 10 18:37 accounts
drwx------ 4 root root  4096 mar  8 09:20 archive
drwxr-xr-x 2 root root 20480 mar  8 09:31 csr
drwx------ 2 root root 20480 mar  8 09:31 keys
drwx------ 3 root root  4096 mar  8 09:29 live
drwxr-xr-x 2 root root  4096 mar  8 09:24 renewal
drwxr-xr-x 5 root root  4096 sep 10 18:31 renewal-hooks
ls: cannot open directory '/etc/letsencrypt/accounts': Permission denied
ls: cannot open directory '/etc/letsencrypt/archive': Permission denied
/etc/letsencrypt/csr:
total 1588
-rw-r--r-- 1 root root 936 sep 10 18:38 0000_csr-certbot.pem
-rw-r--r-- 1 root root 944 sep 28 11:46 0001_csr-certbot.pem
-rw-r--r-- 1 root root 936 oct  2 17:49 0002_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 10 01:25 0003_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 11 15:35 0004_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 12 01:26 0005_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 12 15:36 0006_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 13 01:23 0007_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 13 15:39 0008_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 14 01:22 0009_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 14 15:42 0010_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 15 01:25 0011_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 15 15:36 0012_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 16 01:20 0013_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 16 15:38 0014_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 17 01:24 0015_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 17 15:42 0016_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 18 01:27 0017_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 18 15:40 0018_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 19 01:25 0019_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 19 15:38 0020_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 20 01:24 0021_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 20 15:37 0022_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 21 01:22 0023_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 21 15:39 0024_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 22 01:26 0025_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 22 15:37 0026_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 23 01:22 0027_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 23 15:38 0028_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 24 01:24 0029_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 24 15:35 0030_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 25 01:28 0031_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 25 15:38 0032_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 26 01:24 0033_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 26 15:38 0034_csr-certbot.pem
-rw-r--r-- 1 root root 944 nov 28 01:27 0035_csr-certbot.pem
-rw-r--r-- 1 root root 944 nov 29 01:25 0036_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 29 01:26 0037_csr-certbot.pem
-rw-r--r-- 1 root root 944 nov 30 01:22 0038_csr-certbot.pem
-rw-r--r-- 1 root root 944 nov 30 15:39 0039_csr-certbot.pem
-rw-r--r-- 1 root root 936 nov 30 15:39 0040_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  1 01:24 0041_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  1 01:25 0042_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  1 15:43 0043_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  1 15:43 0044_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  1 20:43 0045_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  1 20:43 0046_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  1 20:43 0047_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  2 04:57 0048_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  2 04:57 0049_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  2 04:57 0050_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  2 20:43 0051_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  2 20:43 0052_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  2 20:44 0053_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  3 05:05 0054_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  3 05:05 0055_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  3 05:05 0056_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  3 20:44 0057_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  3 20:44 0058_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  3 20:44 0059_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  4 03:20 0060_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  4 03:20 0061_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  4 03:20 0062_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  4 12:19 0063_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  4 12:19 0064_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  4 12:19 0065_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  5 03:17 0066_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  5 03:17 0067_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  5 03:17 0068_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  5 12:24 0069_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  5 12:24 0070_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  5 12:24 0071_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  6 03:15 0072_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  6 03:15 0073_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  6 03:15 0074_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  6 12:20 0075_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  6 12:20 0076_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  6 12:21 0077_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  7 03:18 0078_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  7 03:18 0079_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  7 03:19 0080_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  7 12:24 0081_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  7 12:24 0082_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  7 12:24 0083_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  8 03:14 0084_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  8 03:14 0085_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  8 03:15 0086_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  8 12:22 0087_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  8 12:22 0088_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  8 12:23 0089_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  9 03:18 0090_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 03:18 0091_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 03:18 0092_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:30 0093_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:32 0094_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:37 0095_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:40 0096_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:41 0097_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:43 0098_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:44 0099_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:48 0100_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 08:51 0101_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 09:02 0102_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 10:38 0103_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 10:40 0104_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 10:43 0105_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic  9 12:24 0106_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic  9 12:24 0107_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 10 03:15 0108_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 10 03:15 0109_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 10 12:22 0110_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 10 12:22 0111_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 11 03:14 0112_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 11 03:14 0113_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 11 12:19 0114_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 11 12:19 0115_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 12 03:20 0116_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 12 03:20 0117_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 12 12:21 0118_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 12 12:21 0119_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 13 03:20 0120_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 13 03:20 0121_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 13 12:17 0122_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 13 12:18 0123_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 14 03:20 0124_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 14 03:20 0125_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 14 12:24 0126_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 14 12:24 0127_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 15 03:15 0128_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 15 03:15 0129_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 15 12:23 0130_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 15 12:23 0131_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 16 03:20 0132_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 16 03:20 0133_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 16 12:25 0134_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 16 12:25 0135_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 17 03:18 0136_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 17 03:18 0137_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 17 12:24 0138_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 17 12:24 0139_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 18 03:16 0140_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 18 03:16 0141_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 18 12:24 0142_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 18 12:24 0143_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 19 03:17 0144_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 19 03:17 0145_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 19 12:20 0146_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 19 12:20 0147_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 20 03:19 0148_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 20 03:19 0149_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 20 12:19 0150_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 20 12:19 0151_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 21 03:21 0152_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 21 03:21 0153_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 21 12:20 0154_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 21 12:20 0155_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 22 03:18 0156_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 22 03:18 0157_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 22 12:23 0158_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 22 12:23 0159_csr-certbot.pem
-rw-r--r-- 1 root root 936 dic 22 19:31 0160_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 23 03:20 0161_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 23 12:18 0162_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 24 03:19 0163_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 24 12:23 0164_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 25 12:17 0165_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 26 03:20 0166_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 26 12:21 0167_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 27 03:16 0168_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 27 12:17 0169_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 28 03:15 0170_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 28 12:22 0171_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 29 03:18 0172_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 29 12:18 0173_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 30 03:13 0174_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 30 12:17 0175_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 31 03:17 0176_csr-certbot.pem
-rw-r--r-- 1 root root 944 dic 31 12:18 0177_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  1 03:15 0178_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  1 12:17 0179_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  2 03:18 0180_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  2 12:17 0181_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  3 03:15 0182_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  3 12:17 0183_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  4 03:17 0184_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  4 12:25 0185_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  5 03:14 0186_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  5 12:17 0187_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  5 21:28 0188_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  6 10:31 0189_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  6 21:27 0190_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  7 10:33 0191_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  7 21:32 0192_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  8 10:33 0193_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  8 21:30 0194_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  9 10:34 0195_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene  9 21:31 0196_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 10 10:27 0197_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 10 21:29 0198_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 11 10:30 0199_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 11 21:27 0200_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 12 10:28 0201_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 12 21:31 0202_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 13 10:34 0203_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 13 21:32 0204_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 14 10:30 0205_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 14 21:31 0206_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 15 10:32 0207_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 15 21:32 0208_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 16 10:31 0209_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 16 21:30 0210_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 17 10:34 0211_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 17 21:28 0212_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 18 10:32 0213_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 18 21:28 0214_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 19 10:27 0215_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 19 21:29 0216_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 20 10:33 0217_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 20 21:29 0218_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 21 10:30 0219_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 21 21:27 0220_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 22 10:27 0221_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 22 21:31 0222_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 23 10:32 0223_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 23 21:32 0224_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 24 10:33 0225_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 25 10:29 0226_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 25 21:25 0227_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 26 10:30 0228_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 26 21:32 0229_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 27 10:32 0230_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 27 21:32 0231_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 28 10:34 0232_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 28 21:29 0233_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 29 10:29 0234_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 29 21:30 0235_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 30 10:34 0236_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 30 21:31 0237_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 31 10:33 0238_csr-certbot.pem
-rw-r--r-- 1 root root 944 ene 31 21:28 0239_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  1 10:28 0240_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  1 21:30 0241_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  2 10:34 0242_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  3 05:22 0243_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  3 12:58 0244_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  4 05:21 0245_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  4 12:59 0246_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  5 05:24 0247_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  5 12:54 0248_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  6 05:23 0249_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  6 12:58 0250_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  7 05:21 0251_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  7 12:54 0252_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb  7 12:54 0253_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  8 05:19 0254_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb  8 05:19 0255_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  8 12:55 0256_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb  8 12:55 0257_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  9 05:24 0258_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb  9 05:24 0259_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb  9 12:55 0260_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb  9 12:55 0261_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 10 05:24 0262_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 10 05:24 0263_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 10 12:58 0264_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 10 12:58 0265_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 11 05:22 0266_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 11 05:22 0267_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 11 12:57 0268_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 11 12:57 0269_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 12 05:21 0270_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 12 05:21 0271_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 12 12:58 0272_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 12 12:58 0273_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 13 05:17 0274_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 13 05:17 0275_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 13 13:02 0276_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 13 13:02 0277_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 14 05:21 0278_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 14 05:21 0279_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 14 12:56 0280_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 14 12:56 0281_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 15 05:22 0282_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 15 05:22 0283_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 15 13:00 0284_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 15 13:00 0285_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 16 05:23 0286_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 16 05:23 0287_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 16 12:57 0288_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 16 12:57 0289_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 17 05:18 0290_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 17 05:19 0291_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 17 10:32 0292_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 17 12:57 0293_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 17 12:57 0294_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 18 05:21 0295_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 18 05:21 0296_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 18 13:01 0297_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 18 13:02 0298_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 19 05:20 0299_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 19 05:20 0300_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 19 12:57 0301_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 19 12:57 0302_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 20 05:20 0303_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 20 05:20 0304_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 20 12:58 0305_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 20 12:58 0306_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 21 05:25 0307_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 21 05:25 0308_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 21 05:25 0309_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 21 12:57 0310_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 21 12:57 0311_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 21 12:57 0312_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 22 05:22 0313_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 22 05:22 0314_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 22 05:22 0315_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 22 12:56 0316_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 22 12:56 0317_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 22 12:56 0318_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 23 05:19 0319_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 23 05:19 0320_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 23 05:19 0321_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 23 12:55 0322_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 23 12:55 0323_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 23 12:55 0324_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 24 05:19 0325_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 24 05:19 0326_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 24 05:19 0327_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 24 12:55 0328_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 24 12:55 0329_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 24 12:56 0330_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 25 05:23 0331_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 25 05:23 0332_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 25 05:23 0333_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 25 12:58 0334_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 25 12:58 0335_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 25 12:58 0336_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 26 05:24 0337_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 26 05:24 0338_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 26 05:24 0339_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 26 13:02 0340_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 26 13:02 0341_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 26 13:02 0342_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 27 05:18 0343_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 27 05:19 0344_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 27 05:19 0345_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 27 12:55 0346_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 27 12:55 0347_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 27 12:55 0348_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 28 05:19 0349_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 28 05:19 0350_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 28 05:19 0351_csr-certbot.pem
-rw-r--r-- 1 root root 944 feb 28 13:01 0352_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 28 13:01 0353_csr-certbot.pem
-rw-r--r-- 1 root root 936 feb 28 13:01 0354_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  1 05:24 0355_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  1 05:24 0356_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  1 05:24 0357_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  1 12:56 0358_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  1 12:56 0359_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  1 12:56 0360_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  2 05:21 0361_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  2 05:21 0362_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  2 05:21 0363_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  2 12:58 0364_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  2 12:58 0365_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  2 12:58 0366_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  3 05:25 0367_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  3 05:25 0368_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  3 05:25 0369_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  3 13:02 0370_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  3 13:02 0371_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  3 13:02 0372_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  4 02:16 0373_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  4 02:16 0374_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  4 02:16 0375_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  4 18:25 0376_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  4 18:25 0377_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  4 18:25 0378_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  5 02:17 0379_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  5 02:17 0380_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  5 02:17 0381_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  5 18:26 0382_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  5 18:26 0383_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  5 18:26 0384_csr-certbot.pem
-rw-r--r-- 1 root root 944 mar  6 02:17 0385_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  6 02:17 0386_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  6 02:17 0387_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  6 09:11 0388_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  6 09:12 0389_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  6 10:25 0390_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  6 18:26 0391_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  7 02:16 0392_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  7 18:21 0393_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  8 02:19 0394_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  8 09:30 0395_csr-certbot.pem
-rw-r--r-- 1 root root 936 mar  8 09:31 0396_csr-certbot.pem
ls: cannot open directory '/etc/letsencrypt/keys': Permission denied
ls: cannot open directory '/etc/letsencrypt/live': Permission denied
/etc/letsencrypt/renewal:
total 4
-rw-r--r-- 1 root root 665 dic 22 19:34 monitoreogchu.ddns.net.conf
/etc/letsencrypt/renewal-hooks:
total 12
drwxr-xr-x 2 root root 4096 sep 10 18:31 deploy
drwxr-xr-x 2 root root 4096 sep 10 18:31 post
drwxr-xr-x 2 root root 4096 sep 10 18:31 pre
/etc/letsencrypt/renewal-hooks/deploy:
total 0
/etc/letsencrypt/renewal-hooks/post:
total 0
/etc/letsencrypt/renewal-hooks/pre:
total 0
CON SUDO ****************************************************************************************************************************
/etc/letsencrypt/:
total 68
/etc/letsencrypt/accounts:
total 4
drwx------ 3 root root 4096 sep 10 18:37 acme-v02.api.letsencrypt.org
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org:
total 4
drwx------ 3 root root 4096 sep 10 18:38 directory
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory:
total 4
drwx------ 2 root root 4096 sep 10 18:38 1190497f10844aaabc55710a553b026e
/etc/letsencrypt/accounts/acme-v02.api.letsencrypt.org/directory/1190497f10844aaabc55710a553b026e:
total 12
-rw-r--r-- 1 root root   69 sep 10 18:39 meta.json
-r-------- 1 root root 1632 sep 10 18:38 private_key.json
-rw-r--r-- 1 root root   78 sep 10 18:38 regr.json
/etc/letsencrypt/archive:
total 8
drwxr-xr-x 2 root root 4096 dic 22 19:34 monitoreogchu.ddns.net
drwxr-xr-x 2 root root 4096 feb 17 10:34 osm.gualeguaychu.gov.ar
/etc/letsencrypt/archive/monitoreogchu.ddns.net:
total 32
-rw-r--r-- 1 root root 1927 oct  2 17:50 cert1.pem
-rw-r--r-- 1 root root 1862 dic 22 19:34 cert2.pem
-rw-r--r-- 1 root root 1647 oct  2 17:50 chain1.pem
-rw-r--r-- 1 root root 1586 dic 22 19:34 chain2.pem
-rw-r--r-- 1 root root 3574 oct  2 17:50 fullchain1.pem
-rw-r--r-- 1 root root 3448 dic 22 19:34 fullchain2.pem
-rw------- 1 root root 1708 oct  2 17:50 privkey1.pem
-rw------- 1 root root 1704 dic 22 19:34 privkey2.pem
/etc/letsencrypt/archive/osm.gualeguaychu.gov.ar:
total 32
-rw-r--r-- 1 root root 1935 sep 10 18:39 cert1.pem
-rw-r--r-- 1 root root 1866 feb 17 10:34 cert2.pem
-rw-r--r-- 1 root root 1647 sep 10 18:39 chain1.pem
-rw-r--r-- 1 root root 1586 feb 17 10:34 chain2.pem
-rw-r--r-- 1 root root 3582 sep 10 18:39 fullchain1.pem
-rw-r--r-- 1 root root 3452 feb 17 10:34 fullchain2.pem
-rw------- 1 root root 1708 dic  9 10:00 privkey1.pem
-rw------- 1 root root 1704 feb 17 10:34 privkey2.pem
total 1588
/etc/letsencrypt/keys:
total 1588
-rw------- 1 root root 1708 sep 10 18:38 0000_key-certbot.pem
-rw------- 1 root root 1704 sep 28 11:46 0001_key-certbot.pem
-rw------- 1 root root 1708 oct  2 17:49 0002_key-certbot.pem
-rw------- 1 root root 1704 nov 10 01:25 0003_key-certbot.pem
-rw------- 1 root root 1704 nov 11 15:35 0004_key-certbot.pem
-rw------- 1 root root 1704 nov 12 01:26 0005_key-certbot.pem
-rw------- 1 root root 1704 nov 12 15:36 0006_key-certbot.pem
-rw------- 1 root root 1708 nov 13 01:23 0007_key-certbot.pem
-rw------- 1 root root 1704 nov 13 15:39 0008_key-certbot.pem
-rw------- 1 root root 1704 nov 14 01:22 0009_key-certbot.pem
-rw------- 1 root root 1704 nov 14 15:42 0010_key-certbot.pem
-rw------- 1 root root 1704 nov 15 01:25 0011_key-certbot.pem
-rw------- 1 root root 1704 nov 15 15:36 0012_key-certbot.pem
-rw------- 1 root root 1704 nov 16 01:20 0013_key-certbot.pem
-rw------- 1 root root 1708 nov 16 15:38 0014_key-certbot.pem
-rw------- 1 root root 1704 nov 17 01:24 0015_key-certbot.pem
-rw------- 1 root root 1704 nov 17 15:42 0016_key-certbot.pem
-rw------- 1 root root 1704 nov 18 01:27 0017_key-certbot.pem
-rw------- 1 root root 1704 nov 18 15:40 0018_key-certbot.pem
-rw------- 1 root root 1704 nov 19 01:25 0019_key-certbot.pem
-rw------- 1 root root 1704 nov 19 15:38 0020_key-certbot.pem
-rw------- 1 root root 1704 nov 20 01:24 0021_key-certbot.pem
-rw------- 1 root root 1704 nov 20 15:37 0022_key-certbot.pem
-rw------- 1 root root 1704 nov 21 01:22 0023_key-certbot.pem
-rw------- 1 root root 1704 nov 21 15:39 0024_key-certbot.pem
-rw------- 1 root root 1704 nov 22 01:26 0025_key-certbot.pem
-rw------- 1 root root 1704 nov 22 15:37 0026_key-certbot.pem
-rw------- 1 root root 1704 nov 23 01:22 0027_key-certbot.pem
-rw------- 1 root root 1704 nov 23 15:38 0028_key-certbot.pem
-rw------- 1 root root 1704 nov 24 01:24 0029_key-certbot.pem
-rw------- 1 root root 1704 nov 24 15:35 0030_key-certbot.pem
-rw------- 1 root root 1704 nov 25 01:28 0031_key-certbot.pem
-rw------- 1 root root 1708 nov 25 15:38 0032_key-certbot.pem
-rw------- 1 root root 1704 nov 26 01:24 0033_key-certbot.pem
-rw------- 1 root root 1708 nov 26 15:38 0034_key-certbot.pem
-rw------- 1 root root 1704 nov 28 01:27 0035_key-certbot.pem
-rw------- 1 root root 1704 nov 29 01:25 0036_key-certbot.pem
-rw------- 1 root root 1704 nov 29 01:26 0037_key-certbot.pem
-rw------- 1 root root 1704 nov 30 01:22 0038_key-certbot.pem
-rw------- 1 root root 1704 nov 30 15:39 0039_key-certbot.pem
-rw------- 1 root root 1708 nov 30 15:39 0040_key-certbot.pem
-rw------- 1 root root 1704 dic  1 01:24 0041_key-certbot.pem
-rw------- 1 root root 1704 dic  1 01:25 0042_key-certbot.pem
-rw------- 1 root root 1704 dic  1 15:43 0043_key-certbot.pem
-rw------- 1 root root 1708 dic  1 15:43 0044_key-certbot.pem
-rw------- 1 root root 1704 dic  1 20:43 0045_key-certbot.pem
-rw------- 1 root root 1704 dic  1 20:43 0046_key-certbot.pem
-rw------- 1 root root 1708 dic  1 20:43 0047_key-certbot.pem
-rw------- 1 root root 1704 dic  2 04:57 0048_key-certbot.pem
-rw------- 1 root root 1704 dic  2 04:57 0049_key-certbot.pem
-rw------- 1 root root 1704 dic  2 04:57 0050_key-certbot.pem
-rw------- 1 root root 1704 dic  2 20:43 0051_key-certbot.pem
-rw------- 1 root root 1704 dic  2 20:43 0052_key-certbot.pem
-rw------- 1 root root 1704 dic  2 20:44 0053_key-certbot.pem
-rw------- 1 root root 1704 dic  3 05:05 0054_key-certbot.pem
-rw------- 1 root root 1704 dic  3 05:05 0055_key-certbot.pem
-rw------- 1 root root 1704 dic  3 05:05 0056_key-certbot.pem
-rw------- 1 root root 1704 dic  3 20:44 0057_key-certbot.pem
-rw------- 1 root root 1704 dic  3 20:44 0058_key-certbot.pem
-rw------- 1 root root 1704 dic  3 20:44 0059_key-certbot.pem
-rw------- 1 root root 1704 dic  4 03:20 0060_key-certbot.pem
-rw------- 1 root root 1708 dic  4 03:20 0061_key-certbot.pem
-rw------- 1 root root 1708 dic  4 03:20 0062_key-certbot.pem
-rw------- 1 root root 1704 dic  4 12:19 0063_key-certbot.pem
-rw------- 1 root root 1704 dic  4 12:19 0064_key-certbot.pem
-rw------- 1 root root 1704 dic  4 12:19 0065_key-certbot.pem
-rw------- 1 root root 1708 dic  5 03:17 0066_key-certbot.pem
-rw------- 1 root root 1704 dic  5 03:17 0067_key-certbot.pem
-rw------- 1 root root 1704 dic  5 03:17 0068_key-certbot.pem
-rw------- 1 root root 1704 dic  5 12:24 0069_key-certbot.pem
-rw------- 1 root root 1708 dic  5 12:24 0070_key-certbot.pem
-rw------- 1 root root 1704 dic  5 12:24 0071_key-certbot.pem
-rw------- 1 root root 1704 dic  6 03:15 0072_key-certbot.pem
-rw------- 1 root root 1704 dic  6 03:15 0073_key-certbot.pem
-rw------- 1 root root 1704 dic  6 03:15 0074_key-certbot.pem
-rw------- 1 root root 1708 dic  6 12:20 0075_key-certbot.pem
-rw------- 1 root root 1704 dic  6 12:20 0076_key-certbot.pem
-rw------- 1 root root 1704 dic  6 12:21 0077_key-certbot.pem
-rw------- 1 root root 1704 dic  7 03:18 0078_key-certbot.pem
-rw------- 1 root root 1704 dic  7 03:18 0079_key-certbot.pem
-rw------- 1 root root 1708 dic  7 03:19 0080_key-certbot.pem
-rw------- 1 root root 1704 dic  7 12:24 0081_key-certbot.pem
-rw------- 1 root root 1704 dic  7 12:24 0082_key-certbot.pem
-rw------- 1 root root 1704 dic  7 12:24 0083_key-certbot.pem
-rw------- 1 root root 1708 dic  8 03:14 0084_key-certbot.pem
-rw------- 1 root root 1704 dic  8 03:14 0085_key-certbot.pem
-rw------- 1 root root 1708 dic  8 03:15 0086_key-certbot.pem
-rw------- 1 root root 1704 dic  8 12:22 0087_key-certbot.pem
-rw------- 1 root root 1704 dic  8 12:22 0088_key-certbot.pem
-rw------- 1 root root 1704 dic  8 12:23 0089_key-certbot.pem
-rw------- 1 root root 1708 dic  9 03:18 0090_key-certbot.pem
-rw------- 1 root root 1704 dic  9 03:18 0091_key-certbot.pem
-rw------- 1 root root 1708 dic  9 03:18 0092_key-certbot.pem
-rw------- 1 root root 1708 dic  9 08:30 0093_key-certbot.pem
-rw------- 1 root root 1704 dic  9 08:32 0094_key-certbot.pem
-rw------- 1 root root 1704 dic  9 08:37 0095_key-certbot.pem
-rw------- 1 root root 1708 dic  9 08:40 0096_key-certbot.pem
-rw------- 1 root root 1704 dic  9 08:41 0097_key-certbot.pem
-rw------- 1 root root 1704 dic  9 08:43 0098_key-certbot.pem
-rw------- 1 root root 1708 dic  9 08:44 0099_key-certbot.pem
-rw------- 1 root root 1704 dic  9 08:48 0100_key-certbot.pem
-rw------- 1 root root 1704 dic  9 08:51 0101_key-certbot.pem
-rw------- 1 root root 1704 dic  9 09:02 0102_key-certbot.pem
-rw------- 1 root root 1704 dic  9 10:38 0103_key-certbot.pem
-rw------- 1 root root 1704 dic  9 10:40 0104_key-certbot.pem
-rw------- 1 root root 1704 dic  9 10:43 0105_key-certbot.pem
-rw------- 1 root root 1704 dic  9 12:24 0106_key-certbot.pem
-rw------- 1 root root 1704 dic  9 12:24 0107_key-certbot.pem
-rw------- 1 root root 1704 dic 10 03:15 0108_key-certbot.pem
-rw------- 1 root root 1704 dic 10 03:15 0109_key-certbot.pem
-rw------- 1 root root 1704 dic 10 12:22 0110_key-certbot.pem
-rw------- 1 root root 1704 dic 10 12:22 0111_key-certbot.pem
-rw------- 1 root root 1704 dic 11 03:14 0112_key-certbot.pem
-rw------- 1 root root 1708 dic 11 03:14 0113_key-certbot.pem
-rw------- 1 root root 1708 dic 11 12:19 0114_key-certbot.pem
-rw------- 1 root root 1704 dic 11 12:19 0115_key-certbot.pem
-rw------- 1 root root 1708 dic 12 03:20 0116_key-certbot.pem
-rw------- 1 root root 1704 dic 12 03:20 0117_key-certbot.pem
-rw------- 1 root root 1704 dic 12 12:21 0118_key-certbot.pem
-rw------- 1 root root 1704 dic 12 12:21 0119_key-certbot.pem
-rw------- 1 root root 1704 dic 13 03:20 0120_key-certbot.pem
-rw------- 1 root root 1704 dic 13 03:20 0121_key-certbot.pem
-rw------- 1 root root 1704 dic 13 12:17 0122_key-certbot.pem
-rw------- 1 root root 1704 dic 13 12:18 0123_key-certbot.pem
-rw------- 1 root root 1704 dic 14 03:20 0124_key-certbot.pem
-rw------- 1 root root 1704 dic 14 03:20 0125_key-certbot.pem
-rw------- 1 root root 1708 dic 14 12:24 0126_key-certbot.pem
-rw------- 1 root root 1708 dic 14 12:24 0127_key-certbot.pem
-rw------- 1 root root 1704 dic 15 03:15 0128_key-certbot.pem
-rw------- 1 root root 1704 dic 15 03:15 0129_key-certbot.pem
-rw------- 1 root root 1704 dic 15 12:23 0130_key-certbot.pem
-rw------- 1 root root 1704 dic 15 12:23 0131_key-certbot.pem
-rw------- 1 root root 1708 dic 16 03:20 0132_key-certbot.pem
-rw------- 1 root root 1704 dic 16 03:20 0133_key-certbot.pem
-rw------- 1 root root 1704 dic 16 12:25 0134_key-certbot.pem
-rw------- 1 root root 1704 dic 16 12:25 0135_key-certbot.pem
-rw------- 1 root root 1708 dic 17 03:18 0136_key-certbot.pem
-rw------- 1 root root 1704 dic 17 03:18 0137_key-certbot.pem
-rw------- 1 root root 1708 dic 17 12:24 0138_key-certbot.pem
-rw------- 1 root root 1704 dic 17 12:24 0139_key-certbot.pem
-rw------- 1 root root 1704 dic 18 03:16 0140_key-certbot.pem
-rw------- 1 root root 1704 dic 18 03:16 0141_key-certbot.pem
-rw------- 1 root root 1708 dic 18 12:24 0142_key-certbot.pem
-rw------- 1 root root 1704 dic 18 12:24 0143_key-certbot.pem
-rw------- 1 root root 1708 dic 19 03:17 0144_key-certbot.pem
-rw------- 1 root root 1704 dic 19 03:17 0145_key-certbot.pem
-rw------- 1 root root 1704 dic 19 12:20 0146_key-certbot.pem
-rw------- 1 root root 1704 dic 19 12:20 0147_key-certbot.pem
-rw------- 1 root root 1704 dic 20 03:19 0148_key-certbot.pem
-rw------- 1 root root 1704 dic 20 03:19 0149_key-certbot.pem
-rw------- 1 root root 1704 dic 20 12:19 0150_key-certbot.pem
-rw------- 1 root root 1704 dic 20 12:19 0151_key-certbot.pem
-rw------- 1 root root 1704 dic 21 03:21 0152_key-certbot.pem
-rw------- 1 root root 1704 dic 21 03:21 0153_key-certbot.pem
-rw------- 1 root root 1708 dic 21 12:20 0154_key-certbot.pem
-rw------- 1 root root 1704 dic 21 12:20 0155_key-certbot.pem
-rw------- 1 root root 1704 dic 22 03:18 0156_key-certbot.pem
-rw------- 1 root root 1704 dic 22 03:18 0157_key-certbot.pem
-rw------- 1 root root 1704 dic 22 12:23 0158_key-certbot.pem
-rw------- 1 root root 1704 dic 22 12:23 0159_key-certbot.pem
-rw------- 1 root root 1704 dic 22 19:31 0160_key-certbot.pem
-rw------- 1 root root 1704 dic 23 03:20 0161_key-certbot.pem
-rw------- 1 root root 1704 dic 23 12:18 0162_key-certbot.pem
-rw------- 1 root root 1708 dic 24 03:19 0163_key-certbot.pem
-rw------- 1 root root 1708 dic 24 12:23 0164_key-certbot.pem
-rw------- 1 root root 1704 dic 25 12:17 0165_key-certbot.pem
-rw------- 1 root root 1704 dic 26 03:20 0166_key-certbot.pem
-rw------- 1 root root 1704 dic 26 12:21 0167_key-certbot.pem
-rw------- 1 root root 1704 dic 27 03:16 0168_key-certbot.pem
-rw------- 1 root root 1704 dic 27 12:17 0169_key-certbot.pem
-rw------- 1 root root 1704 dic 28 03:15 0170_key-certbot.pem
-rw------- 1 root root 1704 dic 28 12:22 0171_key-certbot.pem
-rw------- 1 root root 1708 dic 29 03:18 0172_key-certbot.pem
-rw------- 1 root root 1704 dic 29 12:18 0173_key-certbot.pem
-rw------- 1 root root 1708 dic 30 03:13 0174_key-certbot.pem
-rw------- 1 root root 1704 dic 30 12:17 0175_key-certbot.pem
-rw------- 1 root root 1704 dic 31 03:17 0176_key-certbot.pem
-rw------- 1 root root 1704 dic 31 12:18 0177_key-certbot.pem
-rw------- 1 root root 1704 ene  1 03:15 0178_key-certbot.pem
-rw------- 1 root root 1704 ene  1 12:17 0179_key-certbot.pem
-rw------- 1 root root 1704 ene  2 03:18 0180_key-certbot.pem
-rw------- 1 root root 1704 ene  2 12:17 0181_key-certbot.pem
-rw------- 1 root root 1704 ene  3 03:15 0182_key-certbot.pem
-rw------- 1 root root 1704 ene  3 12:17 0183_key-certbot.pem
-rw------- 1 root root 1704 ene  4 03:17 0184_key-certbot.pem
-rw------- 1 root root 1704 ene  4 12:25 0185_key-certbot.pem
-rw------- 1 root root 1708 ene  5 03:14 0186_key-certbot.pem
-rw------- 1 root root 1704 ene  5 12:17 0187_key-certbot.pem
-rw------- 1 root root 1704 ene  5 21:28 0188_key-certbot.pem
-rw------- 1 root root 1700 ene  6 10:31 0189_key-certbot.pem
-rw------- 1 root root 1704 ene  6 21:27 0190_key-certbot.pem
-rw------- 1 root root 1704 ene  7 10:33 0191_key-certbot.pem
-rw------- 1 root root 1708 ene  7 21:32 0192_key-certbot.pem
-rw------- 1 root root 1708 ene  8 10:33 0193_key-certbot.pem
-rw------- 1 root root 1704 ene  8 21:30 0194_key-certbot.pem
-rw------- 1 root root 1708 ene  9 10:34 0195_key-certbot.pem
-rw------- 1 root root 1704 ene  9 21:31 0196_key-certbot.pem
-rw------- 1 root root 1708 ene 10 10:27 0197_key-certbot.pem
-rw------- 1 root root 1704 ene 10 21:29 0198_key-certbot.pem
-rw------- 1 root root 1704 ene 11 10:30 0199_key-certbot.pem
-rw------- 1 root root 1708 ene 11 21:27 0200_key-certbot.pem
-rw------- 1 root root 1708 ene 12 10:28 0201_key-certbot.pem
-rw------- 1 root root 1704 ene 12 21:31 0202_key-certbot.pem
-rw------- 1 root root 1704 ene 13 10:34 0203_key-certbot.pem
-rw------- 1 root root 1704 ene 13 21:32 0204_key-certbot.pem
-rw------- 1 root root 1704 ene 14 10:30 0205_key-certbot.pem
-rw------- 1 root root 1704 ene 14 21:31 0206_key-certbot.pem
-rw------- 1 root root 1704 ene 15 10:32 0207_key-certbot.pem
-rw------- 1 root root 1704 ene 15 21:32 0208_key-certbot.pem
-rw------- 1 root root 1708 ene 16 10:31 0209_key-certbot.pem
-rw------- 1 root root 1704 ene 16 21:30 0210_key-certbot.pem
-rw------- 1 root root 1704 ene 17 10:34 0211_key-certbot.pem
-rw------- 1 root root 1704 ene 17 21:28 0212_key-certbot.pem
-rw------- 1 root root 1704 ene 18 10:32 0213_key-certbot.pem
-rw------- 1 root root 1704 ene 18 21:28 0214_key-certbot.pem
-rw------- 1 root root 1704 ene 19 10:27 0215_key-certbot.pem
-rw------- 1 root root 1704 ene 19 21:29 0216_key-certbot.pem
-rw------- 1 root root 1704 ene 20 10:33 0217_key-certbot.pem
-rw------- 1 root root 1704 ene 20 21:29 0218_key-certbot.pem
-rw------- 1 root root 1704 ene 21 10:30 0219_key-certbot.pem
-rw------- 1 root root 1704 ene 21 21:27 0220_key-certbot.pem
-rw------- 1 root root 1704 ene 22 10:27 0221_key-certbot.pem
-rw------- 1 root root 1708 ene 22 21:31 0222_key-certbot.pem
-rw------- 1 root root 1708 ene 23 10:32 0223_key-certbot.pem
-rw------- 1 root root 1708 ene 23 21:32 0224_key-certbot.pem
-rw------- 1 root root 1704 ene 24 10:33 0225_key-certbot.pem
-rw------- 1 root root 1704 ene 25 10:29 0226_key-certbot.pem
-rw------- 1 root root 1704 ene 25 21:25 0227_key-certbot.pem
-rw------- 1 root root 1704 ene 26 10:30 0228_key-certbot.pem
-rw------- 1 root root 1704 ene 26 21:32 0229_key-certbot.pem
-rw------- 1 root root 1704 ene 27 10:32 0230_key-certbot.pem
-rw------- 1 root root 1704 ene 27 21:32 0231_key-certbot.pem
-rw------- 1 root root 1704 ene 28 10:34 0232_key-certbot.pem
-rw------- 1 root root 1704 ene 28 21:29 0233_key-certbot.pem
-rw------- 1 root root 1708 ene 29 10:29 0234_key-certbot.pem
-rw------- 1 root root 1708 ene 29 21:30 0235_key-certbot.pem
-rw------- 1 root root 1704 ene 30 10:34 0236_key-certbot.pem
-rw------- 1 root root 1704 ene 30 21:31 0237_key-certbot.pem
-rw------- 1 root root 1704 ene 31 10:33 0238_key-certbot.pem
-rw------- 1 root root 1704 ene 31 21:28 0239_key-certbot.pem
-rw------- 1 root root 1704 feb  1 10:28 0240_key-certbot.pem
-rw------- 1 root root 1708 feb  1 21:30 0241_key-certbot.pem
-rw------- 1 root root 1704 feb  2 10:34 0242_key-certbot.pem
-rw------- 1 root root 1704 feb  3 05:22 0243_key-certbot.pem
-rw------- 1 root root 1704 feb  3 12:58 0244_key-certbot.pem
-rw------- 1 root root 1704 feb  4 05:21 0245_key-certbot.pem
-rw------- 1 root root 1704 feb  4 12:59 0246_key-certbot.pem
-rw------- 1 root root 1704 feb  5 05:24 0247_key-certbot.pem
-rw------- 1 root root 1704 feb  5 12:54 0248_key-certbot.pem
-rw------- 1 root root 1704 feb  6 05:23 0249_key-certbot.pem
-rw------- 1 root root 1704 feb  6 12:58 0250_key-certbot.pem
-rw------- 1 root root 1704 feb  7 05:21 0251_key-certbot.pem
-rw------- 1 root root 1708 feb  7 12:54 0252_key-certbot.pem
-rw------- 1 root root 1704 feb  7 12:54 0253_key-certbot.pem
-rw------- 1 root root 1704 feb  8 05:19 0254_key-certbot.pem
-rw------- 1 root root 1704 feb  8 05:19 0255_key-certbot.pem
-rw------- 1 root root 1708 feb  8 12:55 0256_key-certbot.pem
-rw------- 1 root root 1704 feb  8 12:55 0257_key-certbot.pem
-rw------- 1 root root 1704 feb  9 05:24 0258_key-certbot.pem
-rw------- 1 root root 1704 feb  9 05:24 0259_key-certbot.pem
-rw------- 1 root root 1704 feb  9 12:55 0260_key-certbot.pem
-rw------- 1 root root 1708 feb  9 12:55 0261_key-certbot.pem
-rw------- 1 root root 1704 feb 10 05:24 0262_key-certbot.pem
-rw------- 1 root root 1708 feb 10 05:24 0263_key-certbot.pem
-rw------- 1 root root 1704 feb 10 12:58 0264_key-certbot.pem
-rw------- 1 root root 1704 feb 10 12:58 0265_key-certbot.pem
-rw------- 1 root root 1704 feb 11 05:22 0266_key-certbot.pem
-rw------- 1 root root 1704 feb 11 05:22 0267_key-certbot.pem
-rw------- 1 root root 1708 feb 11 12:57 0268_key-certbot.pem
-rw------- 1 root root 1704 feb 11 12:57 0269_key-certbot.pem
-rw------- 1 root root 1708 feb 12 05:21 0270_key-certbot.pem
-rw------- 1 root root 1704 feb 12 05:21 0271_key-certbot.pem
-rw------- 1 root root 1704 feb 12 12:58 0272_key-certbot.pem
-rw------- 1 root root 1704 feb 12 12:58 0273_key-certbot.pem
-rw------- 1 root root 1704 feb 13 05:17 0274_key-certbot.pem
-rw------- 1 root root 1704 feb 13 05:17 0275_key-certbot.pem
-rw------- 1 root root 1708 feb 13 13:02 0276_key-certbot.pem
-rw------- 1 root root 1708 feb 13 13:02 0277_key-certbot.pem
-rw------- 1 root root 1704 feb 14 05:21 0278_key-certbot.pem
-rw------- 1 root root 1704 feb 14 05:21 0279_key-certbot.pem
-rw------- 1 root root 1708 feb 14 12:56 0280_key-certbot.pem
-rw------- 1 root root 1704 feb 14 12:56 0281_key-certbot.pem
-rw------- 1 root root 1704 feb 15 05:22 0282_key-certbot.pem
-rw------- 1 root root 1708 feb 15 05:22 0283_key-certbot.pem
-rw------- 1 root root 1704 feb 15 13:00 0284_key-certbot.pem
-rw------- 1 root root 1704 feb 15 13:00 0285_key-certbot.pem
-rw------- 1 root root 1704 feb 16 05:23 0286_key-certbot.pem
-rw------- 1 root root 1704 feb 16 05:23 0287_key-certbot.pem
-rw------- 1 root root 1704 feb 16 12:57 0288_key-certbot.pem
-rw------- 1 root root 1708 feb 16 12:57 0289_key-certbot.pem
-rw------- 1 root root 1704 feb 17 05:18 0290_key-certbot.pem
-rw------- 1 root root 1708 feb 17 05:19 0291_key-certbot.pem
-rw------- 1 root root 1704 feb 17 10:32 0292_key-certbot.pem
-rw------- 1 root root 1704 feb 17 12:57 0293_key-certbot.pem
-rw------- 1 root root 1704 feb 17 12:57 0294_key-certbot.pem
-rw------- 1 root root 1708 feb 18 05:21 0295_key-certbot.pem
-rw------- 1 root root 1704 feb 18 05:21 0296_key-certbot.pem
-rw------- 1 root root 1704 feb 18 13:01 0297_key-certbot.pem
-rw------- 1 root root 1704 feb 18 13:02 0298_key-certbot.pem
-rw------- 1 root root 1704 feb 19 05:20 0299_key-certbot.pem
-rw------- 1 root root 1708 feb 19 05:20 0300_key-certbot.pem
-rw------- 1 root root 1708 feb 19 12:57 0301_key-certbot.pem
-rw------- 1 root root 1704 feb 19 12:57 0302_key-certbot.pem
-rw------- 1 root root 1708 feb 20 05:20 0303_key-certbot.pem
-rw------- 1 root root 1704 feb 20 05:20 0304_key-certbot.pem
-rw------- 1 root root 1704 feb 20 12:58 0305_key-certbot.pem
-rw------- 1 root root 1704 feb 20 12:58 0306_key-certbot.pem
-rw------- 1 root root 1704 feb 21 05:25 0307_key-certbot.pem
-rw------- 1 root root 1704 feb 21 05:25 0308_key-certbot.pem
-rw------- 1 root root 1708 feb 21 05:25 0309_key-certbot.pem
-rw------- 1 root root 1708 feb 21 12:57 0310_key-certbot.pem
-rw------- 1 root root 1704 feb 21 12:57 0311_key-certbot.pem
-rw------- 1 root root 1704 feb 21 12:57 0312_key-certbot.pem
-rw------- 1 root root 1704 feb 22 05:22 0313_key-certbot.pem
-rw------- 1 root root 1704 feb 22 05:22 0314_key-certbot.pem
-rw------- 1 root root 1704 feb 22 05:22 0315_key-certbot.pem
-rw------- 1 root root 1704 feb 22 12:56 0316_key-certbot.pem
-rw------- 1 root root 1704 feb 22 12:56 0317_key-certbot.pem
-rw------- 1 root root 1704 feb 22 12:56 0318_key-certbot.pem
-rw------- 1 root root 1704 feb 23 05:19 0319_key-certbot.pem
-rw------- 1 root root 1704 feb 23 05:19 0320_key-certbot.pem
-rw------- 1 root root 1704 feb 23 05:19 0321_key-certbot.pem
-rw------- 1 root root 1708 feb 23 12:55 0322_key-certbot.pem
-rw------- 1 root root 1704 feb 23 12:55 0323_key-certbot.pem
-rw------- 1 root root 1704 feb 23 12:55 0324_key-certbot.pem
-rw------- 1 root root 1704 feb 24 05:19 0325_key-certbot.pem
-rw------- 1 root root 1708 feb 24 05:19 0326_key-certbot.pem
-rw------- 1 root root 1704 feb 24 05:19 0327_key-certbot.pem
-rw------- 1 root root 1704 feb 24 12:55 0328_key-certbot.pem
-rw------- 1 root root 1704 feb 24 12:55 0329_key-certbot.pem
-rw------- 1 root root 1704 feb 24 12:56 0330_key-certbot.pem
-rw------- 1 root root 1704 feb 25 05:23 0331_key-certbot.pem
-rw------- 1 root root 1704 feb 25 05:23 0332_key-certbot.pem
-rw------- 1 root root 1704 feb 25 05:23 0333_key-certbot.pem
-rw------- 1 root root 1708 feb 25 12:58 0334_key-certbot.pem
-rw------- 1 root root 1704 feb 25 12:58 0335_key-certbot.pem
-rw------- 1 root root 1704 feb 25 12:58 0336_key-certbot.pem
-rw------- 1 root root 1704 feb 26 05:24 0337_key-certbot.pem
-rw------- 1 root root 1704 feb 26 05:24 0338_key-certbot.pem
-rw------- 1 root root 1704 feb 26 05:24 0339_key-certbot.pem
-rw------- 1 root root 1704 feb 26 13:02 0340_key-certbot.pem
-rw------- 1 root root 1704 feb 26 13:02 0341_key-certbot.pem
-rw------- 1 root root 1704 feb 26 13:02 0342_key-certbot.pem
-rw------- 1 root root 1704 feb 27 05:18 0343_key-certbot.pem
-rw------- 1 root root 1708 feb 27 05:19 0344_key-certbot.pem
-rw------- 1 root root 1704 feb 27 05:19 0345_key-certbot.pem
-rw------- 1 root root 1704 feb 27 12:55 0346_key-certbot.pem
-rw------- 1 root root 1704 feb 27 12:55 0347_key-certbot.pem
-rw------- 1 root root 1704 feb 27 12:55 0348_key-certbot.pem
-rw------- 1 root root 1704 feb 28 05:19 0349_key-certbot.pem
-rw------- 1 root root 1704 feb 28 05:19 0350_key-certbot.pem
-rw------- 1 root root 1704 feb 28 05:19 0351_key-certbot.pem
-rw------- 1 root root 1704 feb 28 13:01 0352_key-certbot.pem
-rw------- 1 root root 1704 feb 28 13:01 0353_key-certbot.pem
-rw------- 1 root root 1704 feb 28 13:01 0354_key-certbot.pem
-rw------- 1 root root 1704 mar  1 05:24 0355_key-certbot.pem
-rw------- 1 root root 1704 mar  1 05:24 0356_key-certbot.pem
-rw------- 1 root root 1704 mar  1 05:24 0357_key-certbot.pem
-rw------- 1 root root 1704 mar  1 12:56 0358_key-certbot.pem
-rw------- 1 root root 1704 mar  1 12:56 0359_key-certbot.pem
-rw------- 1 root root 1704 mar  1 12:56 0360_key-certbot.pem
-rw------- 1 root root 1704 mar  2 05:21 0361_key-certbot.pem
-rw------- 1 root root 1708 mar  2 05:21 0362_key-certbot.pem
-rw------- 1 root root 1704 mar  2 05:21 0363_key-certbot.pem
-rw------- 1 root root 1708 mar  2 12:58 0364_key-certbot.pem
-rw------- 1 root root 1708 mar  2 12:58 0365_key-certbot.pem
-rw------- 1 root root 1704 mar  2 12:58 0366_key-certbot.pem
-rw------- 1 root root 1708 mar  3 05:25 0367_key-certbot.pem
-rw------- 1 root root 1704 mar  3 05:25 0368_key-certbot.pem
-rw------- 1 root root 1704 mar  3 05:25 0369_key-certbot.pem
-rw------- 1 root root 1704 mar  3 13:02 0370_key-certbot.pem
-rw------- 1 root root 1704 mar  3 13:02 0371_key-certbot.pem
-rw------- 1 root root 1704 mar  3 13:02 0372_key-certbot.pem
-rw------- 1 root root 1704 mar  4 02:16 0373_key-certbot.pem
-rw------- 1 root root 1704 mar  4 02:16 0374_key-certbot.pem
-rw------- 1 root root 1704 mar  4 02:16 0375_key-certbot.pem
-rw------- 1 root root 1708 mar  4 18:25 0376_key-certbot.pem
-rw------- 1 root root 1704 mar  4 18:25 0377_key-certbot.pem
-rw------- 1 root root 1704 mar  4 18:25 0378_key-certbot.pem
-rw------- 1 root root 1708 mar  5 02:17 0379_key-certbot.pem
-rw------- 1 root root 1704 mar  5 02:17 0380_key-certbot.pem
-rw------- 1 root root 1708 mar  5 02:17 0381_key-certbot.pem
-rw------- 1 root root 1704 mar  5 18:26 0382_key-certbot.pem
-rw------- 1 root root 1704 mar  5 18:26 0383_key-certbot.pem
-rw------- 1 root root 1700 mar  5 18:26 0384_key-certbot.pem
-rw------- 1 root root 1704 mar  6 02:17 0385_key-certbot.pem
-rw------- 1 root root 1704 mar  6 02:17 0386_key-certbot.pem
-rw------- 1 root root 1708 mar  6 02:17 0387_key-certbot.pem
-rw------- 1 root root 1704 mar  6 09:11 0388_key-certbot.pem
-rw------- 1 root root 1704 mar  6 09:12 0389_key-certbot.pem
-rw------- 1 root root 1704 mar  6 10:25 0390_key-certbot.pem
-rw------- 1 root root 1704 mar  6 18:26 0391_key-certbot.pem
-rw------- 1 root root 1704 mar  7 02:16 0392_key-certbot.pem
-rw------- 1 root root 1704 mar  7 18:21 0393_key-certbot.pem
-rw------- 1 root root 1704 mar  8 02:19 0394_key-certbot.pem
-rw------- 1 root root 1708 mar  8 09:30 0395_key-certbot.pem
-rw------- 1 root root 1704 mar  8 09:31 0396_key-certbot.pem
/etc/letsencrypt/live:
total 12
-rw-r--r-- 1 root root   63 feb 17 10:33 leer
drwxr-xr-x 2 root root 4096 feb 23 11:07 monitoreogchu.ddns.net
-rw-r--r-- 1 root root  740 sep 10 18:39 README
/etc/letsencrypt/live/monitoreogchu.ddns.net:
total 4
lrwxrwxrwx 1 root root  46 dic 22 19:34 cert.pem -> ../../archive/monitoreogchu.ddns.net/cert2.pem
lrwxrwxrwx 1 root root  47 dic 22 19:34 chain.pem -> ../../archive/monitoreogchu.ddns.net/chain2.pem
lrwxrwxrwx 1 root root  51 dic 22 19:34 fullchain.pem -> ../../archive/monitoreogchu.ddns.net/fullchain2.pem
lrwxrwxrwx 1 root root  49 dic 22 19:34 privkey.pem -> ../../archive/monitoreogchu.ddns.net/privkey2.pem
-rw-r--r-- 1 root root 692 oct  2 17:50 README
total 4
total 12
total 0
total 0
total 0
La próxima vez, si quieres borrar un dominio usa el comando certbot delete
Aunque sólo te permite 3 certificados, podrás seguir renovando tu certificado por eso no te preocupes pero al tratarse de otra CA este tema se sale del ámbito de este foro.
Veo que sigues teniendo alguna referencia a tu dominio en /etc/letsencrypt/archive/osm.gualeguaychu.gov.ar pero de momento no lo borres, o si quieres borrarlo hazte una copia de seguridad porque ahí sigues teniendo un certificado válido emitido el 17 de Febrero que podrías estar usando ahora mismo.
total 32
Lo que me preocupa es que certbot sigue intentando obtener un certificado, esto lo vemos en las últimas entradas del directorio csr y del directory keys, de hecho hoy mismo se ha intentado 3 veces:
total 1588
total 1588
Para saber a qué dominio hace referencia el fichero csr muestra la salida de este comando.
sudo openssl req -noout -text -in /etc/letsencrypt/csr/0396_csr-certbot.pem | grep DNS
Dado que ya no tienes referencias a tu dominio (salvo en archive) me hace pensar que tienes alguna entrada en cron que está lanzando el comando certbot.
Muestra la salida de estos tres comandos:
sudo grep -ri certbot /etc/cron*
sudo crontab -l
sudo systemctl list-timers --all
Salida del comando: sudo openssl req -noout -text -in /etc/letsencrypt/csr/0396_csr-certbot.pem | grep DNS
DNS:osm.gualeguaychu.gov.ar
El comando: sudo grep -ri certbot /etc/cron* no muestra nada
Salida del comando: sudo crontab -l
No crontab for root
Salida del comando: sudo systemctl list-timers --all (veo aca esta el tema snap.certbot.renew.timer)
NEXT                         LEFT          LAST                         PASSED       UNIT                         ACTIVATES
Mon 2021-03-08 20:59:31 -03  2h 17min left Mon 2021-03-08 15:40:30 -03  3h 1min ago  apt-daily.timer              apt-daily.service
Tue 2021-03-09 00:41:33 -03  5h 59min left Mon 2021-03-08 17:16:06 -03  1h 25min ago motd-news.timer              motd-news.service
Tue 2021-03-09 02:15:00 -03  7h left       Mon 2021-03-08 18:20:05 -03  21min ago    snap.certbot.renew.timer     snap.certbot.renew.service
Tue 2021-03-09 06:11:40 -03  11h left      Mon 2021-03-08 06:49:59 -03  11h ago      apt-daily-upgrade.timer      apt-daily-upgrade.service
Tue 2021-03-09 08:44:53 -03  14h left      Mon 2021-03-08 08:44:53 -03  9h ago       systemd-tmpfiles-clean.timer systemd-tmpfiles-clean.service
Mon 2021-03-15 00:00:00 -03  6 days left   Mon 2021-03-08 00:00:10 -03  18h ago      fstrim.timer                 fstrim.service
n/a                          n/a           n/a                          n/a          snapd.snap-repair.timer      snapd.snap-repair.service
n/a                          n/a           n/a                          n/a          ureadahead-stop.timer        ureadahead-stop.service
8 timers listed.
¿Puedo volver a cero la configuracion de Certbot?
Ademas de por los reiterados intentos ¿porque puede ser que Certbot no pueda actualizar el certificado?
Gracias por tu paciencia.
Esto nos confirma que hay algo que está intentando renovar/crear un certificado para tu dominio y se supone que ya no tienes nada de este dominio en /etc/letsencrypt/.
Ese es el timer usado por el paquete snap de certbot y es el encargado de renovar los certificados existentes cuando queden menos de 30 días para que expiren pero lo dicho, no debería intentar renovar un certificado para el que ya no hay ninguna configuración.
Realmente ya lo tienes, como he comentado antes, únicamente te falta borrar el directorio /etc/letsencrypt/archive/osm.gualeguaychu.gov.ar (haz un backup antes) y ya no habrá ninguna referencia a este dominio en la configuración de letsencrypt.
Ahora mismo ya no podemos hablar de actualizar el certificado puesto que no queda ninguna referencia a el, tendremos que verlo cuando vayas a crear un nuevo certificado para el dominio.
De momento muestra la salida de estos dos comandos (el primer comando es simplemente para ver qué salida muestra certbot al intentar renovar los certificados y es básicamente lo que hará el timer de certbot. El segundo comando es para ver si algún usuario de tu sistema está lanzando algún comando usando certbot, lo que podría explicar lo que te está ocurriendo):
sudo certbot renew
sudo grep -Ri certbot /var/spool/cron/crontabs/
Un placer :wink:
Salida de: sudo certbot renew
Processing /etc/letsencrypt/renewal/monitoreogchu.ddns.net.conf
Renewing an existing certificate for monitoreogchu.ddns.net
http-01 challenge for monitoreogchu.ddns.net
Challenge failed for domain monitoreogchu.ddns.net
Failed to renew certificate monitoreogchu.ddns.net with error: Some challenges have failed.
  /etc/letsencrypt/live/monitoreogchu.ddns.net/fullchain.pem (failure)
   Domain: monitoreogchu.ddns.net
   Type:   connection
   Detail: Fetching
   http://monitoreogchu.ddns.net/.well-known/acme-challenge/MzKiEvh9Jod44rn7iHFr2QjsbwPAVyuLfPMISLpQs9k:
   Connection refused
sudo grep -Ri certbot /var/spool/cron/crontabs/ no muestra nada
La salida de certbot renew es correcta, no hace referencia a osm.gualeguaychu.gov.ar así que eso es bueno. El hecho de que no renueve el certificado de monitoreogchu.ddns.net es otro problema, no sé si sigues necesitando un certificado para ese dominio.
De momento sólo podemos esperar al 10 de marzo de 2021 a las 16:02:00 UTC para intentar obtener un nuevo certificado para el dominio osm.gualeguaychu.gov.ar. Tendrás que usar el mismo comando que usaste para obtenerlo la primera vez.
Perfecto, muchas gracias por ahora, mas adelante pruebo a ver que pasa.
El certificado de monitoreogchu.ddns.net da error porque no estaba corriendo el servidor http
Recién corrí el servidor y renové el certificado sin problemas.
Si tengo algún problema puedo escribir en este mismo tema o tengo que crear uno nuevo ?Muuuchas gracias por tu ayuda y paciencia.
Perfecto.
Mejor en este mismo tema así no perdemos el hilo y de nada :wink:
