Error 403 using --expand
My domain is: www.gesundetiere.de
certbot-auto --expand -d tierfundus.de,www.tierfundus.de,gesundetiere.de,www.gesundetiere.de
terminal:
Domain: www.gesundetiere.de
Detail: Invalid response from . . .
http://www.gesundetiere.de/
letsencrypt.log:
  "type": "http-01",
  "status": "invalid",
  "error": {
    "type": "urn:ietf:params:acme:error:unauthorized", . . .
   "detail": "Invalid response from http://www.gesundetiere.de
    "status": 403
My web server is (include version): Apache/2.4.7 (Ubuntu)
The operating system my web server runs on is (include version): ubuntu 14.04
My hosting provider, if applicable, is: ionos.de
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.30.2
Hello,
I have been using a let’s encrypt certificate for the domains tierfundus.de and www.tierfundus.de for years. Now you want to add the domains gesundetiere.de and www.gesundetiere.de.
I try to accomplish this by using --expand as shown above.
For both new domains, error 403 occurs.
Many thanks in advance for advices
Which authenticator is Certbot using for this certificate?
This detail is included in the full output of Certbot.
I cannot find anything like authenticator in then letsencrypt.log.
Is that anywhere else or how can I find what you are looking for?
It should be there, somewhere at the top when the command is ran.
You can also paste it here, preferably through sites such as pastebin.
In the meantime I found what you mean:
DEBUG:certbot.plugins.selection:Requested authenticator None and installer None
And here you find the complete log:
https://pastebin.com/z7Rb8wvC
Hi @khg
do these domains (later) have different content? Or have they all the same webroot in your webserver-configuration?
You have old certificates from 2016-07-17, so perhaps you have used the deprecated tls-sni-validation.
Checking /.well-known/acme-challenge/random-filename your gesundetiere.de has a good http status 404, your tierfundus.de has a forbidden.
So check your Apache to find your "DocumentRoot". But before running the next command it's important to know if all domains have the same DocumentRoot.
they have different DocumentRoot:
 DocumentRoot /var/www/wordpress
 ServerName www.gesundetiere.de
 ServerAlias gesundetiere.de
www.tierfundus.de is connected to a Java-EE application:
            ServerName www.tierfundus.de
	#ServerAlias tierfundus.de
DocumentRoot /var/www/tierfundus
             JkMount /* ajp13_worker
Oh, is it really a good idea to create one certificate with both domain names?
Use your current certificate with gesundetiere.de and create a second certificate with the new domain name.
OK, I didn’t expect problems with one certificate. But I will now create a second one.
Thank you
PS: tierfundus.de has already a Letsencrypt certificate:
CN=tierfundus.de
	20.01.2019
	20.04.2019
	tierfundus.de, www.tierfundus.de - 2 entries
But now your other domain has the wrong certificate.
One or two hours earlier I saw another thing - tierfundus was blocked, gesundetiere worked.
Does your Jave-App use the same webroot?
Apache's mod_jk uses a custom network transport to talk to the Java application.
OP would need to use --apache authenticator to make it work, but even then I'm not sure how compatible it is with mod_jk.
tierfundus.de and gesundetiere.de point to total different sites (Wordpress and JavaEE).
Therefore, I agree with you, it is better to create two different certificates.
