Elasticsearch Shield SSL using single signed certificate for domain
I`m using Elasticsearch 2.2.0 with shield 2.2. The cluster has a 100 nodes on different servers in AWS environment under one domain:
es1.test.domainname.com
es2.test.domainname.com
es3.test.domainname.com
es4.test.domainname.com
es5.test.domainname.com
es6.test.domainname.com
es99.test.domainname.com
es100.test.domainname.com
I want to enable ssl in Shield and for that I need to issue a signed certificate as I already described in other question. The problem here is that for each new elastic node I would need to issue new signed certificate so the node could join the ssl protected cluster… Right now I have already “spent” all of my weekly subdomains requests.
Is it possible to sign only one certificate for test.domainname.com and copy it to all the other nodes (different servers same domain)?
Yes, you can have up to 100 SANs on a single cert, you only need multiple certs if you have more than that.
@cool110 - It didn't work. I tried to sign csr for test.domainname.com and got :
Failed authorization procedure. test.domainname.com (tls-sni-01): urn:acme:error:connection :: The server could not connect to the client to verify the domain :: DNS problem: NXDOMAIN looking up A for test.domainname.com
Domain: test.domainname.com
Type: connection
Detail: DNS problem: NXDOMAIN looking up A for test.domainname.com
I tried to do so from es1.test.domainname.com (C name by GoDaddy)
Why it is failing?
Don’t put test.domainname.com in the CSR, all 100 subdomains need to be in there. You should get es1.test.domainname.com as the common name but with all the other ones in the alternative names.
but it is not going to work…
say I signed 30 Elasticsearch domains - es1.test.domainname.com as the common name and all the others es2-30 in the alternative names. Ok, but tomorrow I will need to add one more server to the cluster - es31.test.domainname.com- I will need to make another certificate that includes the new server and replace in each elastic server the installed certificate with this new one == nightmare.
Is there a way to sign general domain certificate that I can copy to the sub domain servers?
No, the best way would be to have the unused subdomains pointing at a node that is running or to have all 100 running when issuing (and renewing).
Ok, got it.
The last thing I couldn’t get right is how to make a csr with alternative names…
I tried:
> sudo keytool -importcert -keystore node.jks -file /home/ubuntu/letsencrypt/public_pem/isrgrootx1.pem -alias letsencrypt
> sudo keytool -genkey -alias node -keystore node.jks -keyalg RSA -keysize 2048 -validity 712 -ext san=dns:es1.test.domainname.com
> sudo keytool -certreq -alias node -keystore node.jks -file node.csr -keyalg rsa -ext san=dns:es1.test.domainname.com
> sudo openssl req -outform der -in node.csr -out node.der
> ./letsencrypt-auto auth --csr /etc/elasticsearch/shield/node.der
Where do I set alternative names?
Change that to a comma separated list with each name prefixed with dns:
