Duckdns Unable to determine zone identifier for {0} using zone names: {1}
My domain is: thibleroy.duckdns.org
I ran this command: sudo docker run -it --rm --name certbot -v "/Users/thibleroy/dev/certbot/etc-letsencrypt:/etc/letsencrypt" -v "/Users/thibleroy/dev/certbot/ovh:/secrets" -v "/Users/thibleroy/dev/certbot/var-letsencrypt:/var/lib/letsencrypt" -v "/Users/thibleroy/dev/certbot/logs:/var/log/letsencrypt" certbot/dns-ovh certonly --dns-ovh --dns-ovh-credentials /secrets/ovh.ini --dns-ovh-propagation-seconds 60 -d thibleroy.duckdns.org -v
Plugins selected: Authenticator dns-ovh, Installer None
Requesting a certificate for thibleroy.duckdns.org
dns-01 challenge for thibleroy.duckdns.org
Unable to determine zone identifier for thibleroy.duckdns.org using zone names: ['thibleroy.duckdns.org', 'duckdns.org', 'org']
My web server is (include version): nginx proxy manager v2.11.3
The operating system my web server runs on is (include version): raspbian
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot/dns-ovh v3.0.0
Why are you using certbot-dns-ovh for a DuckDNS domain? That doesn't make much sense..
