Domain Key does not match domain certificate
My domain is: thediscourseng.com
I ran this command: Certificate renewal from zerossl
It produced this output: domain certificate.
My hosting provider, if applicable, is arvixe:
I can login to a root shell on my machine (yes or no, or I don’t know): i dont know how to
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
I installed (copied and pasted) the renewed certificate on my site but i get a notice that the certificate does not match the domain key. please how can i get a domain key for the renewed certificate
I think the key is either the previous key or a new key generated by the client (browser)
Anyway, there is no way we can help you recover / find the key from our side.
You can either reissue the certificate (renew using a new key) or check if you recorded (received) the key before (if certificate key reused)
Thank you
i was not issued a new key on renewal, so its the old key that doesn’t match
Okay.
Can you tell me if you are using the client version of zerossl or web version?
Thank you
i guess web version because i renewed from their website
Okay.
Another question:
Do you use csr or just entered domain name, validate and get a text field of file and keys?
Thank you
i used my LE key and csr
If this is the case, (and suppose you use the csr generated from cPanel server)
Can you try to just fill in the certificate and click on “auto fill by certificate”? (The button should look blue, appear next to the certificate field on cPanel “install ssl” scene)
Thank you
thats the LE key issued to me before
let me try it, thanks.
i did what you suggested but still got the same error messagw ‘the key does not match the certificate’.
Then,
Can you try to issue another certificate? (Use a new generated csr from cPanel , with your LE account key)
Thank you
thanks, i will try it
your idea of generating a new csr worked. thanks
Glad it worked.:slight_smile:
Just for reference: (CSR was used incorrectly. Might used the old csr…and not having the key…)
i think I mixed things up then.
