Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=mopixie.com), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: mopixie.com
I ran this command: ./certbot-auto
It produced this output: Action ‘graceful’ failed.
AH00558: apache2: Could not reliably determine the server’s fully qualified domain name, using 127.0.0.1. Set the ’
ServerName’ directive globally to suppress this message
(98)Address already in use: AH00072: make_sock: could not bind to address [::]:80
(98)Address already in use: AH00072: make_sock: could not bind to address 0.0.0.0:80
no listening sockets available, shutting down
AH00015: Unable to open logs
Unable to restart apache using [‘apache2ctl’, ‘graceful’]
Encountered exception during recovery:
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/error_handler.py”, line 125,
in _call_registered
self.funcs-1
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot/_internal/auth_handler.py”, line 243, i
n _cleanup_challenges
self.auth.cleanup(achalls)
File “/opt/eff.org/certbot/venv/local/lib/python2.7/site-packages/certbot_apache/_internal/configurator.py”, line
2540, in cleanup
self.restart()
2410, in restart
self._reload()
2437, in _reload
raise errors.MisconfigurationError(error)
MisconfigurationError: Error while running apache2ctl graceful.
httpd not running, trying to start
root@wordpress-multisite-1-vm:~#
My web server is (include version): Google Cloud
My hosting provider, if applicable, is: Google Cloud
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 1.4.0
