Docker, Nginx, and LetsEncrypt wildcard cert help
My domain is: *.clearpath.site
#!/bin/bash
if ! [ -x "$(command -v docker-compose)" ]; then
  echo 'Error: docker-compose is not installed.' >&2
  exit 1
fi
domains=(clearpath.site *.clearpath.site)
rsa_key_size=4096
data_path="./nginx/certbot"
email="david@digibrain.co" # Adding a valid address is strongly recommended
staging=1 # Set to 1 if you're testing your setup to avoid hitting request limits
if [ -d "$data_path" ]; then
  read -p "Existing data found for $domains. Continue and replace existing certificate? (y/N) " decision
  if [ "$decision" != "Y" ] && [ "$decision" != "y" ]; then
    exit
  fi
fi
if [ ! -e "$data_path/conf/options-ssl-nginx.conf" ] || [ ! -e "$data_path/conf/ssl-dhparams.pem" ]; then
  echo "### Downloading recommended TLS parameters ..."
  mkdir -p "$data_path/conf"
  curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot-nginx/certbot_nginx/_internal/tls_configs/options-ssl-nginx.conf > "$data_path/conf/options-ssl-nginx.conf"
  curl -s https://raw.githubusercontent.com/certbot/certbot/master/certbot/certbot/ssl-dhparams.pem > "$data_path/conf/ssl-dhparams.pem"
  echo
fi
echo "### Creating dummy certificate for $domains ..."
path="/etc/letsencrypt/live/$domains"
mkdir -p "$data_path/conf/live/$domains"
docker-compose -f docker-compose.prod.yml run --rm --entrypoint "\
  openssl req -x509 -nodes -newkey rsa:$rsa_key_size -days 1\
    -keyout '$path/privkey.pem' \
    -out '$path/fullchain.pem' \
    -subj '/CN=localhost'" certbot
echo
echo "### Starting nginx ..."
docker-compose -f docker-compose.prod.yml up --force-recreate -d nginx
echo
echo "### Deleting dummy certificate for $domains ..."
  rm -Rf /etc/letsencrypt/live/$domains && \
  rm -Rf /etc/letsencrypt/archive/$domains && \
  rm -Rf /etc/letsencrypt/renewal/$domains.conf" certbot
echo
echo "### Requesting Let's Encrypt certificate for $domains ..."
#Join $domains to -d args
domain_args=""
for domain in "${domains[@]}"; do
  domain_args="$domain_args -d $domain"
done
# Select appropriate email arg
case "$email" in
  "") email_arg="--register-unsafely-without-email" ;;
  *) email_arg="--email $email" ;;
esac
# Enable staging mode if needed
if [ $staging != "0" ]; then staging_arg="--staging"; fi
  certbot certonly --webroot -w /var/www/certbot \
    $staging_arg \
    $email_arg \
    $domain_args \
    --rsa-key-size $rsa_key_size \
    --agree-tos \
    --force-renewal" certbot
echo
echo "### Reloading nginx ..."
docker-compose -f docker-compose.prod.yml exec nginx nginx -s reload
### Requesting Let's Encrypt certificate for clearpath.site ...
Creating clearpath_certbot_run ... done
Requesting a certificate for clearpath.site and *.clearpath.site
Client with the currently selected authenticator does not support any combination of challenges that will satisfy the CA. You may need to use an authenticator plugin that can do challenges over DNS.
Docker image: nginx:1.21-alpine
Ubuntu
digitalOcean
Yes
No
Docker image with certbot version: certbot 1.23.0
I am trying to issue a wildcard cert using a bash script which I found here. This script usually works for normal domains but this time I would like to add a wildcard cert.
How can I get a wildcard cert?
The short answer is to use a DNS challenge. See
And
https://eff-certbot.readthedocs.io/en/stable/using.html#dns-plugins
That's not a very good script.
Frankly, it's a terrible script.
I found the script online. Would you mind explaining what is terrible about it?
Btw, I got this issue fixed.
