MikeMcQ
21
Certbot only gets a cert when you use certonly
For nginx, the --nginx plug-in can configure the HTTPS server block (link here)
But, you already get an A on SSL Labs so looks good
https://www.ssllabs.com/ssltest/analyze.html?d=magro-ubezpieczenia.pl&hideResults=on
rbty
22
Is let's encrypt installed on the domain name or on the IP ?
If I want to point another domain name to the same server IP, will I need to take everything from the top or will ssl already be installed?
rg305
24
LE only provides certificates for names [NOT IPs].
You can point many names to the same IP.
Each name will need to be convered by a certificate.
HTTPS://NAME/ [can work]
HTTPS://IP/ [will fail]
system
Closed
25
