Docker cerbot ssl generation issue
shareforcures-local.com
certbot certonly -v --webroot -w /var/www/certbot -d shareforcures-local.com
Requesting a certificate for shareforcures-local.com
http-01 challenge for shareforcures-local.com
Using the webroot path /var/www/certbot for all unmatched domains.
Challenge failed for domain shareforcures-local.com
Domain: shareforcures-local.com
Type: dns
Detail: DNS problem: NXDOMAIN looking up A for shareforcures-local.com - check that a DNS record exists for this domain; DNS problem: NXDOMAIN looking up AAAA for shareforcures-local.com - check that a DNS record exists for this domain
I am using macOS ventura with dockerize environment
my docker compose file is
  nginx:
    image: nginx:1.21.5-alpine
    restart: unless-stopped
    tty: true
    ports:
      - "80:80"
      - "443:443"
    volumes:
      - ./data/certbot/conf:/etc/letsencrypt
      - ./data/certbot/www:/var/www/certbot
      - ./.docker/conf/nginx:/etc/nginx/conf.d
      - ./:/var/www/html
    networks:
      - prometheusresearch
    command: "/bin/sh -c 'while :; do sleep 6h & wait $${!}; nginx -s reload; done & nginx -g \"daemon off;\"'"
  certbot:
    image: certbot/certbot
    volumes:
      - ./.docker/logs:/var/log
    entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
certbot 2.1.1
I can see challenge being generated and then deleted I also hit the url http//shareforcures-local.com/.well-known/acme-challenge/test it works after placing test file there
Hi @mudiman, and welcome to the LE community forum :slight_smile:
Please don't use real "fake" domain names.
You should have read the part you deleted:
Hi @rg305
I want to use local random domain which is not register with any DNS for allowing ssl for local development environment only. I have seen example in forums where example.com or some other local domain are used.
Please start by reading Getting Started - Let's Encrypt
You can find several Free CAs for TLS Certificates here ACME CA Comparison - Posh-ACME
Also please read this Topic's entire thread of Posts Completely LOCAL!
Let’s Encrypt offers Domain Validation (DV) certificates.
For Let’s Encrypt to issue a Domain Validation (DV) certificate Domain Validation must happen.
Thus you need to own and have control over the Domain Name (or have a subdomain under an existing domain name, for example pointed to your server by your employer or school) you wish to obtain a certificate for, from an ICANN Accredited Registrar.
Thanks for all the help
