Hello,
My domain is: supabase.etourne.xyz
I ran this command: docker compose run --rm certbot certonly --webroot --webroot-path /var/www/certbot/ -d supabase.etourne.xyz
Domain: supabase.etourne.xyz
Type: connection
Detail: 140.238.67.63: Fetching http://supabase.etourne.xyz/.well-known/acme-challenge/DSSdnMndAXLPvshkbLGHcTiULQZnPJT-2zAePijzWyg: Error getting validation data
My web server is (include version): nginx:stable-alpine (dockerized)
The operating system my web server runs on is (include version): Canonical-Ubuntu-20.04-aarch64-2023.01.31-0
My hosting provider, if applicable, is: namecheap
or certbot-auto --version
if you're using Certbot): certbot:arm64v8-v2.3.0 (dockerized)
I have dockerized both certbot and Nginx. Here is how my docker compose looks like:
reverse_proxy:
image: nginx:stable-alpine
volumes:
- ./reverse_proxy/nginx.conf:/etc/nginx/conf.d/default.conf/:ro
- ./certbot/www:/var/www/certbot/:ro
- ./certbot/conf/:/etc/nginx/ssl/:ro
restart: always
ports:
- 80:80
certbot:
image: certbot/certbot:arm64v8-v2.3.0
volumes:
- ./certbot/www/:/var/www/certbot/:rw
- ./certbot/conf/:/etc/letsencrypt/:rw
My code in Nginx:
map $http_upgrade $connection_upgrade {
default upgrade;
'' close;
listen 80;gzip on;
listen [::]:80;
server_name supabase.etourne.xyz www.supabase.etourne.xyz;
server_tokens off;
gzip_proxied any;
gzip_comp_level 4;
gzip_types text/css application/javascript image/svg+xml;
# REST API
location ~ ^/rest/v1/(.*)$ {
proxy_set_header Host $host;
proxy_pass http://kong:8000;
proxy_redirect off;
# Authentication
location ~ ^/auth/v1/(.*)$ {
proxy_redirect off;
# Realtime
location ~ ^/realtime/v1/(.*)$ {
proxy_redirect off;
proxy_http_version 1.1;
proxy_set_header Connection $connection_upgrade;
root /var/www/certbot;
proxy_pass http://studio:3000/;
proxy_set_header Connection "upgrade";
proxy_redirect off;
listen 443 default_server ssl http2;
listen [::]:443 ssl http2;
server_name supabase.etourne.xyz;
ssl_certificate /etc/nginx/ssl/live/supabase.etourne.xyz/fullchain.pem;
ssl_certificate_key /etc/nginx/ssl/live/supabase.etourne.xyz/privkey.pem;
